hey guys, i just got a HKS 2835 for my RB20, it has a .72 rear housing on it, just wondering how laggy you guys reckon it would be? is it too big? i also got a .68 housing with it but it needs some work before i can put it on...and my dump wont fit it...let me know what ya think, Cheers
https://www.sau.com.au/forums/topic/210823-hks-2835/
for a 2L engine they dont spool up turbo's very well
compared a RB20 to another 2L engine such as a SR20 and the SR20 is alot more responsive
if ur going to use a HKS 2835 i would highly recommend a .61 exhaust housing
if u cant get ur hands on the HKS .61 exhaust housing the garrett .63 exhaust housing will also fit
https://www.sau.com.au/forums/topic/210823-hks-2835/#findComment-3727739
chuck on the big housing and let it rip
through it on and see
Ive got a feeling it will be on song by 4,000rpm
start making boost about 3-3.5 rpm
If you've got the gear to fit the 0.72 straight up, then give it a run. Don't aim to make the RB20 a low-down torque monster because it will just strangle things up high, where it should be able to shine. Search for threads/posts by Roy regarding the RB20 and turbo specs. Set up, and drive it for what it is - ie. not a RB25, or an SR20. :)
Sounds like you have an oddball pair of housings - Pro and Pro S perhaps? Some of them don't have the T3 flange, depending on the job they were intended to bolt up to. Might be worth checking that aspect, and post some pics if you can. Always interested to see how the HKS castings look.
https://www.sau.com.au/forums/topic/210823-hks-2835/#findComment-3728254
If you've got the gear to fit the 0.72 straight up, then give it a run. Don't aim to make the RB20 a low-down torque monster because it will just strangle things up high, where it should be able to shine. Search for threads/posts by Roy regarding the RB20 and turbo specs. Set up, and drive it for what it is - ie. not a RB25, or an SR20. :no:
yep is a pro s with a .72 'GARRET' rear housing, your right, 20's are so slow down low even with standard turbo, im gonna chuck it on an see how it goes, an if not ill put the .68 on, cant hurt in trying, if its on full boost by 4 ill be happy, keep you posted guys, cheers
https://www.sau.com.au/forums/topic/210823-hks-2835/#findComment-3729698
The fact of the matter is that Garrett don't make a proper turbine housing for that turbine - in any form .
The one they do sell with the T28 flange is a bean counters botch job , bored out GT28 turbine housing that was not designed to work with a GT30 based turbine . Don't let the term "GT2835" fool you because there is NOTHING remotely GT28 about that turbocharger .
The "GT2835" Pro S turbos work best with HKS's housings - period . To use anything else IS a compromise not aimed at power or response .
If you want the best from it use your 0.68 A/R HKS housing because it was designed for your application .
I know it means another dump pipe and thats because their housing/dump combination works better than Nissans original system .
If the 0.71 A/R housing is what I think it is then it's a sort of copy of the Hitachi OP6 or single bb turbo VG30 - sort of .
GT30 based turbines will always give their best results when used in a GT30 based turbine housing .
IMO the HKS Pro S GT30 housing would have less restriction than the other probably aftermarket one even if its A/R number is lower .
A good example is this , Garrett's 0.86 A/R GT28 turbine housing won't outflow their 0.63 A/R T3 one . The A/R number is relevant to the turbine family that the housing is made for - nothing else .
Anyhow I'd use the HKS housing because its a known quantity and designed for the purpose .
Cheers A .
https://www.sau.com.au/forums/topic/210823-hks-2835/#findComment-3729914
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
