Just quickly want to know if the 2 plugs on the R33 gearbox are just a standard plug that can be purchased from any auto shop or from Nissan itself or similar? If so what are they called or part number(s)?
Have a 33 box in my VL, but the plugs on my manual loom are different and need to be swapped over, there is bugger all length on the 33 plug wires so Im not that keen on cutting them back just yet.
Also, whats the easiest way of working out which is the reverse plug and which is the neutral plug?
Thanks...
https://www.sau.com.au/forums/topic/210846-r33-gearbox-plugs/
i dont understand... why dont u cut the plug off the old loom and solder to the new loom... Simple as that... as for which is neutral or reverse... throw a multi meter into the plug and check car in neutral and reverese and it should tell u which is which.
