lol yeah they were removed from the car when i wire brushed and sanded them but mounted them back up because it was the best place to spray all showing areas withought a vice marking certain areas.
good fun and certainly pays off just cant wait till tomorrow when its all dry to stick the new pads and slotted/drilled rotor in! will look a million bucks compared to those old rusy ones
  • Replies 46
hang with wire through a bolt hole :)
I don't know about you guys, but with all my cars, i have only used those $3.00 a spray can and cheap clear coat. And i can assure, they can last for heaps long.
My previous car i owned for about 3 years, did the calipers the first day i owned it, and still looked new when i sold it.
  • 4 weeks later...
  • 5 weeks later...
Trying to decide whether to paint or powdercoat my calipers now...
I was going to take them off and paint them black when replacing my rotors/lines/fluid/pads....but now thinking about powdercoating...if I went that route I'd probably rebuild them at the same time....is it possible for a powdercoater to mask off the NISSAN lettering and powdercoat that a different color, or is that asking too much?
definately possible mate, just whether or not your coater will be willing to do it
I bought a second set of calipers and had them rebuilt, car wasn't off the road that way. Last weekend I sanded back the NISSAN lettering to remove the texture with emery/ fine sand paper to make them smooth. I then cleaned them with thinners, being careful with the seals. I taped up the internals (slow painful job that - longest part of process) and hung them up using a coat hanger around the two bolts/pins for the pads. I painted them in gloss black VHT and then used more emery/fine sand paper to carefully expose the NISSAN lettering, nice and shiny. I then went straight over them in VHT clear coat a few times. If I get round to it I'll post up a photo or two. Hopefully that all sticks well and lasts.
When I get around to swapping the calipers over I will clean the rotor centers and give them a quick paint too. Good thing is I don't have to do fronts and rears in the same day if I don't get around to it.
^^Iam planning to give my calipers a fresh look too. A nice brembo red colour and sand back to see the NISSAN Logo.
By looking at what jenkies did in the photo he posted, looks like he has masked up the areas and just sprayed the caliper without taking it off.
I assume thats fine but you must clean the surface of the caliper right?
I was thinking cleaning the caliper with metholated spirits (right cleaning solution?), give it a good scrub and wipe down then mask it up and spray.
How hot does the calipers heat up to?
VHT should be ok right?
You can paint exhaust mainfolds with VHT so I assume painting a caliper should be fine..?
VHT works fine, mines been VHT gold for 3 or 4 years now. they just dont pop enough for me colour wise.
i used thinners and a wire brush on mine to clean, same deal with not removing them.
waiting for a new candy gold to come in my next batch of powder then i'll get my spares coated.
Cool thanks Craved!
Would you have to do a recoat after sometime?
Cause the calipers can get abit of exposier from the sun, wind and rain...
Few pics of how they came up.. nothing flash but they look better than they did. Maybe a few more coats of clear could possibly help? Even a coat or two of wax to protect them even more.
This is just how I hung them up. Was able to hold coat hanger while painting them and hung them up in between coats. Left arm and shoulder got a little sore after a while holding them up. If you have a place to hange them up and be ablt to paint them in that locatino then that would be best. I was able to tilt the caliper by touching the taped up bleed nipple on the rear.
  • 1 month later...
^ WOW those turned out really good.
i just used VHT paint. Painted mine like 2 years ago and they havnt flaked off etc.
How much did it cost to powdercoat?
yeah VHT does work great, but i still want more gloss than the VHT clear can provide.
those were are fairly big calipers off a 9" rear ended Torana. $40 each might sound expensive, but there is alot more work on them than they look.
Thinking I'll get mine powdercoated now rather than paint them...I was going to paint them as I was planning on doing my rotors/lines/pads with a mate, but being that it needs to be done within the day, the painting would be rushed. So I'll leave it at the workshop the next time its in and get some bits and pieces powdercoated. Hopefully the powdercoater they send it to knows what he's doing with calipers and doesn't ruin them for me :sick:
Just a side question for you chris, is it possible to powdercoat just the hat of a brake rotor, or is there no way to mask the rotor face to withstand the powdercoating process?
sure can do the rotors, did them for this brake setup too. MISSION for taping. took over 30 minutes each to mask up and coat. rears are worse than fronts due to the handbrake surface inside the hat of the rear.
as long as your coater takes plenty of time to do it neatly you wont have an issue - biggest thing is that you have to mask them - then blast them, then clean them, then remask, then coat.
inside and out -
these were solid rears, but you can still to the outer rim of the rotor like i did for this car on the vented rotors.
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
