I have this problem where after I use my indicator I keep hearing the noise sporadically for a few minutes. The indicator isn't flashing on the dash or on the car, it's just making the noise...and it's not the consistent indicator noise as it sometimes goes fast and then slow.
The only that that has been changed in the car since it happened was connecting the LED on my boost guage to the cigarette lighter wiring. Surely this wouldn't have anything to do with it? I dont know if the noise is mechanical or electrical though?
It's really weird...anyone had this prob before? It's an R33 S1 GTST slush
https://www.sau.com.au/forums/topic/210866-indicator-noise-but-no-light/
Its the relay you can hear ticking. if its ticking and your indicator lights arent, its not the indicator circuit or relay causing the problem. It could be an old alarm system relay ticking away. maybe try to locate the relay without pulling to much of ur dash apart
thanks, i'll get a mate to check it out when we take the dash off to paint it. I have NFI what relays are but he should know. It may have been an aftermarket alarm as the little switch spot to the left of the steering wheel is empty, so something was there once but removed before i bought it
a relay is an electrical switch. If you turn off you radio then turn keys from 'acc' to 'on' you'll hear relays click on and the opposite is true when reversed. Voltage goes through a coil which pulls in contacts which completes the circuit (turns on the switch). The one that controls your indicators is called a 'flasher can'.
Good luck searching.
  • 6 months later...
I also have this problem with clicking noise staying on for up to 10 minutes after indicator clicks off, been driving me insane but i should stop being lazy and actually have a look in there - Uneek, how did you go with this?
Cheers
  • 1 year later...
Cheers
I've been in his car.. It's now worse than ever lol
I had this happening to me - After indicating, the stalk would return to neutral but the clicking noise would continue double time.
I ended up taking the assembly off the column to test and i could see it shorting/arcing across the circuits when the stalk returned to the neutral position. I pulled the assembly apart, found the area that was causing the issue and cleaned it up a bit (there was grease everywhere and burnt circuitry in there). Put it all back together and it seemed to fix it for a while, but I think the damage was done and later it would short again intermittently. In the end, I just sourced a replacement stalk and threw away my old one.
Try pulling yours apart - you might be able to get away with just cleaning it up
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
