I have this problem where after I use my indicator I keep hearing the noise sporadically for a few minutes. The indicator isn't flashing on the dash or on the car, it's just making the noise...and it's not the consistent indicator noise as it sometimes goes fast and then slow.
The only that that has been changed in the car since it happened was connecting the LED on my boost guage to the cigarette lighter wiring. Surely this wouldn't have anything to do with it? I dont know if the noise is mechanical or electrical though?
It's really weird...anyone had this prob before? It's an R33 S1 GTST slush
https://www.sau.com.au/forums/topic/210866-indicator-noise-but-no-light/
Its the relay you can hear ticking. if its ticking and your indicator lights arent, its not the indicator circuit or relay causing the problem. It could be an old alarm system relay ticking away. maybe try to locate the relay without pulling to much of ur dash apart
thanks, i'll get a mate to check it out when we take the dash off to paint it. I have NFI what relays are but he should know. It may have been an aftermarket alarm as the little switch spot to the left of the steering wheel is empty, so something was there once but removed before i bought it
a relay is an electrical switch. If you turn off you radio then turn keys from 'acc' to 'on' you'll hear relays click on and the opposite is true when reversed. Voltage goes through a coil which pulls in contacts which completes the circuit (turns on the switch). The one that controls your indicators is called a 'flasher can'.
Good luck searching.
  • 6 months later...
I also have this problem with clicking noise staying on for up to 10 minutes after indicator clicks off, been driving me insane but i should stop being lazy and actually have a look in there - Uneek, how did you go with this?
Cheers
  • 1 year later...
Cheers
I've been in his car.. It's now worse than ever lol
I had this happening to me - After indicating, the stalk would return to neutral but the clicking noise would continue double time.
I ended up taking the assembly off the column to test and i could see it shorting/arcing across the circuits when the stalk returned to the neutral position. I pulled the assembly apart, found the area that was causing the issue and cleaned it up a bit (there was grease everywhere and burnt circuitry in there). Put it all back together and it seemed to fix it for a while, but I think the damage was done and later it would short again intermittently. In the end, I just sourced a replacement stalk and threw away my old one.
Try pulling yours apart - you might be able to get away with just cleaning it up
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to come I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
