I have this problem where after I use my indicator I keep hearing the noise sporadically for a few minutes. The indicator isn't flashing on the dash or on the car, it's just making the noise...and it's not the consistent indicator noise as it sometimes goes fast and then slow.
The only that that has been changed in the car since it happened was connecting the LED on my boost guage to the cigarette lighter wiring. Surely this wouldn't have anything to do with it? I dont know if the noise is mechanical or electrical though?
It's really weird...anyone had this prob before? It's an R33 S1 GTST slush
https://www.sau.com.au/forums/topic/210866-indicator-noise-but-no-light/
Its the relay you can hear ticking. if its ticking and your indicator lights arent, its not the indicator circuit or relay causing the problem. It could be an old alarm system relay ticking away. maybe try to locate the relay without pulling to much of ur dash apart
thanks, i'll get a mate to check it out when we take the dash off to paint it. I have NFI what relays are but he should know. It may have been an aftermarket alarm as the little switch spot to the left of the steering wheel is empty, so something was there once but removed before i bought it
a relay is an electrical switch. If you turn off you radio then turn keys from 'acc' to 'on' you'll hear relays click on and the opposite is true when reversed. Voltage goes through a coil which pulls in contacts which completes the circuit (turns on the switch). The one that controls your indicators is called a 'flasher can'.
Good luck searching.
  • 6 months later...
I also have this problem with clicking noise staying on for up to 10 minutes after indicator clicks off, been driving me insane but i should stop being lazy and actually have a look in there - Uneek, how did you go with this?
Cheers
  • 1 year later...
Cheers
I've been in his car.. It's now worse than ever lol
I had this happening to me - After indicating, the stalk would return to neutral but the clicking noise would continue double time.
I ended up taking the assembly off the column to test and i could see it shorting/arcing across the circuits when the stalk returned to the neutral position. I pulled the assembly apart, found the area that was causing the issue and cleaned it up a bit (there was grease everywhere and burnt circuitry in there). Put it all back together and it seemed to fix it for a while, but I think the damage was done and later it would short again intermittently. In the end, I just sourced a replacement stalk and threw away my old one.
Try pulling yours apart - you might be able to get away with just cleaning it up
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
    • Probably a smart choice to buy one vs build, purely for the motivation part as you said! Imagine the metal dust everywhere from grinding all the steel to build one. Ha ha ha!   Also, post a photo of your garage.   Mine is below, this is where I've been cleaning and have already half filled a caged 6*4 trailer. And this is after my cleaning expedition mentioned previously... The middle normally has a car in it, but I'm dumping things in the middle as I sort through them. And poor skyline was dusty and has had the lightest few drops of rain and now it looks atrocious and needs to be dragged back out and washed thoroughly! And yes to the right is technically another bay, you really can only see 2 bays out of 3 in this picture.
