i had there biggest intercooler ordered,and the guy that i dealt with was good.
asked him questions over the email and didnt even know the guy,got pictures ect...from him
i ordered the cooler and got it delivered to my work the next following day.
i would deal with him again ,no worries.
The only thing is,i didnt order the complete kit as i wanted to have a 3" stainless steel pipings ect,polished(got that done somewhere else,custom made)
Having a Hybrid kit fitted by Liverpool exhaust? that should say something when liverpool sells their own intercoolers if they are sourcing kits from Hybrid instead.
I have seen their kits *(hybrid) they dont vary... they are jigged and fit perfectly and are great value for money. Sounds to me like livo exhaust screwed up the fitting mate......theres more variables than simple the kit... a poor fitting job can make even a HKS/Greddy kit fit badly.
the fmic from hybrid was 600*300*75 and flows really good, no drama.
just that at liverpool exhaust they made the pipes for hybrid.
shouldn't complain, the guy who fitted it was pretty good as he has to adjust the pipes so it fits. just 3-4 gaps needed for engine flex but was wider than originally planned.
but that the last time i fit a gtr style fmic, 2 much cutting and trimming.
but was really effective, 163rwkw at CAS with 12psi, filter & exhaust though stall heaps from all the cold mornings we having in June. unichip fixed the problems.
I don't recommend them. If you'r just buying something of them, maybe Ok, but I think their service to me was rude and unsatisfactory. I had my front bar repaired and repainted and a few other repairs done through them, and I found the workman ship to be very poor. Worst thing was they wouldn't admit it when I showed them.
This happened late last year.
Jim.
But like i always say, everyone has different experiences with different workshops, its a pity but thats life.
I personally like having a jap tuning shop 10 mins from my place so its a convenience thing also.
:uh-huh:
  Quote
Jim.
Was that at Vision or Hybrid?
I just called Hybrid to book my car in for service & was very impressed by their customer service. They're really great guys at hybrid & they definately know their stuff.
But they're really busy at the moment so you may have to wait a while to get any work done.
I bought a car off a guy that had all the work carried out by Hybrid in Sydney, BY BY knows the car. Just let me say i have spent probably 30 or so hours already fixing their dodgy workman ship and im not finished, they also came out and inspected the car when i was buying it from the guy and seen as though they worked on the car they knew jack about it. Heres a little snippet of just a few of the probs i have encountered: they snapped all the plasctic off the afm where they bolt up-so instead of either replacing them or sanding them down neat and round and clamping them they super glued the broke bit and zipped tied them on, or how about instead of clamps holding on my intercooler pipes there was zip ties, they also said they put trust silicone based fluid in for the brakes so i topped it up with a silicone based fluid which then reacted and corroded my brake lines cause in fact it wasnt trust silicone based fluid, or the fact the inlet pipe on the turbo is held on with clamps that have 6mm bolts that were stripped and werent doin anything and letting air in through a 1 inch gap stright onto the turbo wheels, or the fact its a single turbo now yet they left all the piping in for the second turbo instead of simply removing it, thats just the start believe it is just the start nothing major just dodgy little stuff that should have been done right the first time. Also a friend of mine has carried out flow bench tests on hybrid cores and they wont flow enough air for anything over 220kw at the wheels keep this in mind if your looking to do more down the track
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
