Make: Honda EK4 Civic
Model: VTi-R
Milage: 207,XXX
Transmission: Manual
Colour: White
Currently registered? Yes - Rego till Sep 2008
Price: $13,990 $12,490 $11,990
Contact: [email protected]
Comments / Modifications:
I have owned and loved this car almost 3 years. It has been phenomenal, not one problem since I've had it, puts a smile on my face whenever I drive it. The KMs are due to my daily M7 / M2 highway travels to and from work. P-Plater friendly. I have never used any fuel other than 98 Octane, and every 3 - 4 refuels I empty a bottle of Octane Boost + Injector cleaner into it. :) Log books until about 168,000km, then I've changed oil every 5000km ever since using either Motul or Mobil 1. EXTREMELY ECONOMICAL.
Exterior:
Brand new Buddy Club front bar and rear panal, and re-glossed carbon-fibre bonnet done 08/03/08
JUST had its major service 5000km ago and replaced coolant pump
Stock 119kw B16A engine
K&N Filter Pod
Red Civic Type-R engine cover
Cusco Strut Bar
Fully adjustable HSD coilover suspension
Tyres nearly 3 months old - Potenza RE001's, tread almost new
SSA "15 dark gold rims (Rays volk CE28 copies)
Carbon Fibre Bonnet
Full Buddy Club body kit
Cat-back exhaust - stock headers (love the exhaust note)
Fully Electric Sunroof
Philips CrystalVision 4300K Headlights
Interior:
Bride BRIX II reclining Bucket seat
Aftermarket Pioneer CD player/Fusion 6x9s, no subs or amps
Type-R Gear Knob
Mugen Short Shifter (gearbox in mint condition, absolutely no issues shifting)
Fully electric Sunroof
Aircon works perfect
Keyless Entry, power everything
Alarm / Immobilizer
Issues:
Scratch on rear bar, hard to notice
2 small dents in driver's side door
This VTi-R handles and corners superb, very fun, good for track use though I haven't had a chance or money to take it there. The engine feels great healthy and revs very smoothly.
Ideal for any Honda / Civic / Vtec enthusiasts who can really appreciate this car.
Reason for sale,
#1 Pay off debt
#2 try out other cars as I'm an enthusiast, move on
Edited by C00PER
  • 4 weeks later...
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
