If you live near Stafford be careful with letting your pet cats go outside. both of my cats have been missing for a few weeks now. I bet some f#cktard has trapped/killed them. And they were lovely friendly little buggers. I just hope they've shacked up with someone else for a while and they arent in some shallow grave in some yokel cat hunters backyard. :)
https://www.sau.com.au/forums/topic/210909-careful-with-your-pet-cats/
Yet if you say that about someones kid or a possum it heartless...
nah, if u hit a kid who has decided to do chalk drawings on a public road, to bad :) parents should pay for the damage :no: bad parenting / ownership of pet
are you sure someone didnt just run over a cat that shouldnt have been on the road???
When he rips the screen off the window to get out its sorta hard to keep him indoors. I'm sure if you lost 2 pets you'd know how I feel. I've lost 2 family members because some heartless c*nt doesnt like animals, and you give me sh*t about pet ownership. Next time your upset give me a PM so I can be rude to you
:P
Oh man I feel sorry for you :thumbsup: I know what it's like to have a pet go missing. I worry about Tomei, but he always comes home between 9 & 9.30pm, he has a good sense of time LOL oh and they know where the food and warmth is. I hope for your sake they're living with someone else until you can get them back. Are they both chipped?
I lost a pussy once.
It was called fleshlight
lies
you never had pussy, be it real or plastic
Both chipped, desexed vaccinated. My girl is in the pet industry so shes a nazi about that stuff. Doesn't help if they've just been killed and buried, but if someones captured them and hands them in to RSPCA I'll get 'em back. Or if they take them to the vets. Buddy used to come home when I did from work, he would charge up the front steps and into the house as I went in, his timing was that good. Missy was lazy she'd only nick off for an hour or so at a time. Buddy is the stripy bear, Missy the black bear.
    • 1. I can't see a location on your profile but you do mention GBP so I'll assume you are in UK. In Australia, CBC make a timing belt kit with the gears and idler and tension bearing and that is what I use without any problems. I'm sure OEM or HKS are also fine but I wouldn't pay extra for HKS over anything else. 2. Yes, I would always change the idler and tensioner and the stud and bolt that hold them in. Assuming they were all done last time it is highly unlikely you would have a problem, but they are very cheap to add to the job considering the time it will take anyway.  3. No, you don't need to lock them as such (I think that is more for engines without timing marks), but you should make sure they move as little as possible once the belt is off as you can hit pistons on valves if they move too far. As always, make sure you line it all up to top dead centre with the timing marks aligned before you take the old belt off.
    • How to wreak havoc at a bogans party... Swap out the goon bag hanging from the clothes line with oil bag... Watch chaos ensue during Goon of Fortune....
    • Hey everyone,   I’m looking for some advice on replacing the timing belt on my RB25DET Neo-powered 1998 Skyline. The engine was fully built about five years ago, including a fresh timing belt, water pump, and other essentials. However, since then, the car has only covered around 2,000–3,000 miles. It’s currently making around 650hp.   Even though the mileage is low, I know timing belts have a time-based lifespan too, and most recommendations suggest changing them every five to six years or 50,000 miles. Since I’m at that time mark, I’d rather not take any risks and plan to swap it out soon.   A few things I’d like to hear opinions on: 1. What’s the best belt for this setup? Should I go with an OEM Nissan belt, or is the HKS fine-tune a better choice given the power level? 2. Would you bother replacing the idler pulley and tensioner at the same time, or only if they show wear? 3. When swapping the belt, is it necessary to lock the cam and crank gears in place, or is lining up the timing marks enough? I’ve seen different approaches, and I want to make sure I do it right.   The water pump was changed with the rebuild and isn’t run off the timing belt, so I don’t see a need to replace it again. I just want to make sure I approach this the right way.   Any insight would be much appreciated. Thanks!
    • How does this compare to the internally gated g25-550 in terms of power production at same psi and spool
