Hey if Lofty can do 1.17's in his NA 2 litre Toyota Starlet in IPRA form on crap controlled Yokies, why couldn't a car with alot more freedoms and HP/PS/KW go alot faster :D
The most important factor, TALENT. Unfortunately money can't buy it. :)
  • Replies 1.9k
Here is some in car footage from my mates street registered 400hp s14 at Oran park GP
This car does 1.07's at wakefield (old surface). Flat 48's around Oran South and a touch under 1.20 around GP.
This car is running semi's (RE55s).
This car is a consistent front runner and class winner in the Multi Club Supersprint Series in NSW.
I would be very surprised if a street registered car on street tyres could do 1.18 around GP.
Edited by blacksx
Was it you who bought my Brembo's and rotors?
Superlap will be full of surprises!!!!!
What times does this car do around Eeastern Creek???
That's very impressive, street registered rwd 2 litre punching out those times, must be a great steerer too!!!!
Troy (aka Roy) has some stiff competition!!!!
But Troy's racing "twoogle" :laugh:
got a spare pair of -5's hanging around?
JAGR33,
The car in the video is consistently quick. But there is a lot of road registered car's doing similar times.
This car will not be entering superlap. As it is pointless trying to push a 200sx on street tyres around a race track.
Unless it's a drift event which it clearly isn't. These car's need semi's to go quick.
JAGR33,
He should still enter it, will be a great event who cares if there are faster cars out there???
Anyway, still impressive in what your mate has done.. :laugh:
JAGR33,
That S14 looks very well behaved for 400hp! Steerer looks smooth and is on the ball doing those times.
JAG, if you guys did EC as often as you have Sandown/PI etc i suspect you would all be doing around 1:42 to 1:44s. I think that EC is a pretty technical track compared to some down here in Vic. I really need to run my car again on some NSW tracks, never ran on any of them with semis and the TD06 :laugh:
You would really needs 18s on a rwd car in teh Clubsprint class. The extra diam and lower profile would have to help a car on street tyres.
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
