  • Replies 1.9k
changed my mind. I'm going to man up and bring this down for the main game instead. it will probably mean i spend most of the day under the car, re-attaching the turbo each time the studs stretch/come loose but what the hell... someone has to play the cannon fodder role!
quick question - what's the format going to be? do you break us up into groups and have (for eg) 10 minute sessions each like a normal supersprint, or do you get a series of single attempts to set your time - ie out lap, timed lap, in lap?
Oh yes Harry..bring the Datto 1200!!!
This beast is one serious weapon. I have driven this car a couple of times over the years when the previous owner had it. For those that know wakefield, I did a 1.07.20 in it a couple of years ago on old R compounds. I know the car is much better now from when I last drove it.
I love this car.....go the Datto's
HAHAHA I think from memory Jas it was retreads and the trailer. Hang on a minute..I think you car was on the trailer!!!
I still love you Jas, and yes I will let you know when I have a day free for some GP tuition :)
Steve, I am hoping that you will not need the cage so as soon as I know I will let you know. From what I have been told so far you wont need one but I need to clarify that. Either way the class you want to run in next time will not require one :D
Awesome :)
I think its still got the same tyres now!
sheez Bozzy - so much for being an unkown quantity eh?
but that's still seconds off the pace of the Exige - and that's with you at Datsun's wheel! then factor in my fat untalented arse slowing the whole show down...
should probably be a question mark after cheap too...
Expensive Dato race car is cheap cheap Nissan race car. Expecially what is turning up for open class.
very true. its all relative.
have you had your Zed on the scales? I know you've got lots of power but that's still a very impressive time for a big car at a reasonably tight track like Wakefield.
Now that the wheels point straight all the time and it has some consitency in the camber curves it should be a fair bit faster and noticeably easier to drive. Particularly on the technical tracks. Hence why I reckon there's a good 5 seconds or so available at OP GP for a 1.13 maybe a 1.12, the 1.18 doesn't align well with the other times.
If John can coax that out of it on the day, I reckon it will be hard to beat. It's certainly the sort of times, given a dry track, that I expect will be needed to be in there with a chance.
Cheers
Gary
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
