  • Replies 1.9k
Fast fours are looking after all the media side of things so your best option for that is to email [email protected] and ask him as he will be the one giving them out not us.
Cheers
-Nathan
What about recreational photographers? Will there be any areas where non-accredited photographers will be denied access?
How about over 1 sec quicker then JP at PI in crappy, cold and damp conditions. It wasnt wet wet, but there was light rain through the day and even for the brief moments when it was dry it was still frezzing cold and miserable. Better, dry conditions would no doubt be quicker again.
Friggin cheaterer cars :banana:
I'm not 100% on what the story is with this Andrew I would suggest you email Nathan as he will be able to answer that because he is taking care of all the media side of things.
Cheers
-Nathan
I foolishly got all warm and fuzzzy and confessed to Snowman what's under the bonnet now..... Super duper cheaterereer
I will concede that after looking at what times you did at PI in those shitty conditions, i wondered what had been done to your car. I know you had been having overheating problems etc and didnt really get a chance to stretch the cars legs last year, but such an improvement in those conditions, well you are too good a driver to get those sorts of times from mpre track time (ie you are already good, so any improvement wont be seconds (perhaps only tenths) around a race track) Look forward to seeing the car in good conditions.
I really dont think street tyres, obviously they will need to be good ones, is going to hurt the good cars that much. Good suspension and brakes and power only make the car quicker then a lesser car on streets. My car is all gripped up on semis as the tyre masks so many other faults. A well sorted car doesnt need to hide behind tyre grip as you only need a lap time for a single lap
Less grip from the rubber will certainly be interesting. I think the main improvement with my car now is the suspension. The new engine is 390rwkw vs the old engine at 360rwkw. The oversteer issues seem to be ironed out now to the point where I am a bit scared to see how fast it will actually go around a corner ...
a good/well sorted setup for semis won't neccesarily work on road tyres. you generally need a softer, less aggressive setup to get the best out of any kind of low grip condition - whether its caused by rain or tyres...
as for power only making you faster even on street tyres - you've never seen lower powered cars further up the results in the wet?
Did some testing at Winton yesterday for the first time and got some footage. Still have heaps of work to do on the setup if I want to get anywhere near some of the quick RWD's in open class\
Enjoy
name="wmode" value="transparent"></param><embed src="
type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>&">
type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>&" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350" />
Yeah its too soft in the front atm.
1.36.30 which im really happy about as there is so much more to do in the handeling department. Cant wait to see what it does on good tyres.
There were other laps that felt faster but dont have times for them wouldnt have been too much better.
Well done Adz, great time considering your still setting up the car.
I'd say there's at least another second in it without touching it, your lines on some of the corners are robbing you of time.
Big things to come yet from BIGRED...
    • It's impossible to convey what it will feel like to get the right torque. But you can develop a feel for it. A 900mm breaker bar is.....f**king huge. I only use a normal ~400mm one. But with 900mm being very nearly a metre, and the right torque being in the order of 100Nm, then you're going to need a bit over 100N of force, which is about 10 kg. So if you practice using the bar pulling up, instead of pushing down, then it will be about the same effort as lifting a 10kg bucket of water. That's what the pressure against your fingers should feel like. Ish. If you use a more typical length breaker, then it's about twice that. So a good 20 litre bucket, or a little bit more.
    • Also, if anyone has a torque wrench around Williams Landing area and can lend it to me for like 5 mins - I got 4 bottles of Furphy left and I’ll throw that in with a Happy meal 😂
    • So today I decided to bleed my brake fluid, which meant to the wheels came off the car at my garage for the first time. I only had a 90cm breaker bar with me and I noticed that some 1 or 2 lug nuts were a bit hard to get loose (from when the shop did the coilovers) Now.... when it came to putting them back on, I didn't want to put all my weight and overtighten them. So I hand tightened as much as possible and then put normal pressure on the edge of the breaker bar and tightened it until I couldn't turn it anymore without putting in an effort. Do you think that is tight enough? Or is that still too tight?  They are tighter than finger tight. Last thing I want is to have them strip or warp sh*t. But hard times mean I can't just go down to Supercheap and get a torque wrench 🥺
    • Dunno what to tell you, when I look at it on Consult I can see this warmup timing map kicking in around 40C coolant temp and it sticks around for a while:  At part throttle on the normal base timing map it peaks around ~43 degrees of timing or something like that, this warmup timing map drops it to like 12-15 degrees.
    • I don't think that's what you're seeing. Something else doing that. The only time I've seen it get so retarded is when it's trying to control idle (in which case we're not talking about mapped timing tagets anyway) and when there is an extreme coolant temperature sensor fault. The RB26 ECU is essentially the same as the 20 ECU and I knew that ging inside out. There is no facility for it to retard that heavily on cold start. The OEMs never used to do it back then. I mean, shit, the catalyst is abotu 3 miles down the exhaust anyway. Early light-off was just a twinkle in some EPA arsehole's eye back then, not a regular engine control strategy.
