OK Russ what are you up to???
Can't you guys stand still for a while at least?
Beer Baron I have always been the best customer here. Also as Toyota say, "We race we learn you win."
  • Replies 1.9k
Hey crew,
Just letting you know that I am in Perth and have found out we already have 42 people booked for the 5th of June. I think it is being capped at 50.
Get your scates on if you are interested and call me.
0412 574 010
unfortunately I've come across a spot of a cash-flow problem, and as a result my motorsport hobby is on hold :D and my track car is for sale (see link in sig) :bunny:
I don't know a cheaper way to get these kind of lap times - Wakefield 1:07.40, Mt Cotton 46.33 (under IPRA record), Conrod Supersprint 49.47
Not too late for someone to snap it up and enter Superlap...
Hey John what ya reckons will we beat the slot car. We just might have ya lol. :P
bummer on selling your little weapon harry. you are right under $20K to get those sort of times is one hell of a bargain. especially in a car that could be road registered as well. the best part is with relatively smally brakes and wheels and a fairly light car the tyre and brake bills wont send you broke! so it would be a cheap car to race as well as cheap to buy. i'm sure you wont have a problem finding a new home for it. :P if I had space and money it would be on my shortlist no doubt about it.
thanks guys. yep, 400hp and about 900kg does equal alot of smiles anytime you drive it.
kinda hoping it doesn't sell and hopefully I'll get to use it again by the end of the year. so many places I want to take this car and get some laptimes. If I get the job I applied for last week, the car will definitely be coming off the market.
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
