  • Replies 1.9k
I was out there on Sunday afternoon and it was perfect conditions, 19C sunny day no wind.
Far out these things are fast and here is the official times?
Natsoft
I did not get to see these cars and one is Elise Bozman and how do they go so fast? There was a yellow Camano Sports sedan which was the toughest looking thing I have seen at the track and he only did a 1 34. Tube frame fibreglass front end, massive aero and super low roof height and massive slicks with big chev in middle of the car.
Take off the slicks and giants car is much lighter and better suspension etc than when it was there last and ran 1 min 40 last year, and mine is much faster too. I last ran there nearly two years ago and did a 1 43.5. It will still be a big challenge though, as times under 1 min 40 for example even a second is heaps, and THANKS Bozzo.
OK the bar has just been raised for the 5th July!!!!!
Just had a look at the entries and noticed Mackie and Lucas have entered in the exiges!!!!!!!!!!
Peter Lucas just did a 1.34 around the creek on the weekend, while Tim Mackie did a 1.37!!!!!!!
So Lucas is 5 seconds faster than Berry around the creek and 9 seconds faster than Penlington.
Yes these times were done on slicks. These are proper race cars that have entered and are able to run in open. We are all up sh!t creek.
Awesome! IS the specs of the 1:34 and 1:37 cars the same? Im guessing that the 1:34 is the ex-European GT3 Exige or similar etc?
how did they do in the race? is it possible they f**ked the timing? it's happend before many a time. cause bill pye may be just a rich pig farmer but he doesn't mess about. and i would be surprised to see him in his cup car 4 and a half seconds off the pace. I have to say though peter lucas has really bought things on a long way in the last few years. when we ran robs car in prod sports the first 8 or so spots were always filled by 996 cup cars with the few lotus way down the back a fair way off the pace. though I'm guessing peter has upgraded machinery too as he wasn't in A class before in the lotus he was running.
nup, it must be right. he was doing 1:36s in the race. very impressive. :blink: the michelein slicks are a good thing too.
At least these things are not aloud to race and big balls or what??? Sorry coud be female drivers??? NOT>........
http://www.youtube.com/watch?v=bf3cJRkeEqE
All three Elise models on the Lotus website (Elise S, Elise R and Elise SC) are specced with 1.8L engines...
I saw at lotus that sounds similar to this at wakefield late last year. It had an s2000 motor supercharged.
Do they qualify for superlap given they have had a transplant?
I think you will find that they are a K20 front wheel drive engine and gearbox as found in Integra and Civic Type R's.
Cheers
Gary
with turbos on them too I'm guessing???
how does that fit into prod sports? I always thought they had to run the original engine? Marque sports was the "anything goes" category for sports cars... guess it must have changed...
Edited by hrd-hr30
That would be it :P Thanks Gary.
Especially given the standard engine orientation (east west).
They have alloy Honda block and whole car weighs about as much as a big motorbike? No not really but silly light, as in 700kg or less I believe and supercharged not turbo. I might think different about supercharged engines now.
Rather then something that has been bolted together in a backyard i would suggest they are a race derivative of the Exige from one of the European GT3 series. Here are some specs of one i have saved in my favourites :D
- Toyota 1.8 2ZZZ Charge-cooled and supercharged 320bhp
- Dry sump
- Hewland PCT 6 Speed Sequential Transmission (flat shift)
- Limited Slip Differential
- Switchable Traction Control
- 2007 Wide-body
- Quick Release Carbon Fibre Front and Rear Clams and Rear Wing
- Air Jack System
- Digital Dash
- 6-point FIA Approved Roll Cage
- Removeable Steering Wheel
- FIA and HANS Approved Recaro Seat and Race Harness
- Ohlins 4-Way TTX Dampers
- Aluminium Uprights
- AP Twin Master Cylinder System with Dial Bias Adjuster
- 6-Pot AP Front Brake Callipers
- Centre Nut Hubs
- Lotus Sport 5 Spoke Alloy Wheels (10 Inch Rear Wheels)
If i have guessed right then there shouldnt be any real surprise that the thing is as quick as it is
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
