Superlap Timeattack Is Ago!
  • Replies 1.9k
...and I'm out :)
NOOOOOOOOOOOOOOOOOOOOOO!
There will be a next time man. Look at it as a good thing dude. There are always teething problems after a big build. Better they hapen close to home than in another state.
Sorry to hear once again.
Thanks for the offer Steve, but you won't have what I need unfortunately, and I don't want to do a patch job on the car to get it there. It'll be too costly, and the whole reason I pulled the car off the road was to get it all done right :)
Nathan: PM sent mate, don't want to say it publically as it was a custom made part.
Adz: Cheers man. It probably is for the best, and I was always planning on getting a few Sandown runs in before it went as it's nice and close, but it was going to be a midnight on the trailer thing as it was, and this has just thrown a major spanner in the works.
I'm still planning on coming up to check it out, so I'll see you all there :D
A quick question to superlap. How much of the body are you allowed to lighten? Can you replace to whole body with carbon? Or like sports sedans, do you still have to retain the original roof?
Well now that the exiges have entered..........I think they will do 11's or 12's. I think the quickest I have done is a 14, in a restricted GTR. I don't think any GTR will do a 10 or 11 unless they are on a slick. It does not matter how much power you have, it still has to go through 'R' compounds. My opinion anyway :)
I am pretty sure the quickest exige does a 9 on slicks.
So yes my money is on the exiges :sick:
Pppftttt, siff an exige will be the fastest..... :)
TEH GTR CAN NEVA LOSE!!!!!! :)
My money is on a GTR to be the fastest in both classes....
Do not under estimate any Lotus. HKS took the super cheater spec EVO that holds the Tsukuba Super Lap
record to Sepang and there was a car that was developed by Proton or something that wiped the floor with it. It was up for sale a few months ago and sold for about 230,000 pounds.
Just looked to see if there are any vids and i think this is the car
The Lotus Sports Exige 300RR was built for Lotus' parent company, Proton Cars. Based on the award winning aluminum bonded chassis of the production Elise, the Exige 300RR was Intended to be Lotus' reentry into International level motorsports. The one of a kind Exige 300RR is powered by a 400BHP Swindon built GM V6 derived from a DTM unit.
Performance Data
Weight: 1580 lbs
Engine Builder: Swindon
Manufacturer: GM
Type: GM V6 DTM Spec
Displacement: 3000cc
Horsepower: 400BHP
Torque: 340NM
Induction: N/A
Manfacturer: Hewland Sequential
Body Construction: Dry Carbon Fibre
Color: Red/White
Shocks: Ohlins
Brakes: AP Racing
people doing 1:12 and under i just cant get it through my head!!
i was at Oran Park GP yesterday and today for FOSC winter invitation and got a 1:22.6 (on dunlop hard compound semi's) and that was pushing real hard (destroyed my exhaust and alignment - from my aggressive lines:P) and dave raddatz in the mx5mania mx5 on slicks did 1:16s (and he is farkn fast)
would be bloody amazing to see some1 lap at under 1:12!!!
My allignment was also completely shot after a recent outting there as well.
Boz drove the car his way so I started following suit trying to use every last inch of concrete which trashed the allignment but it is all fixable.
Boz drove the car his way so I started following suit trying to use every last inch of concrete which trashed the alignment but it is all fixable.
yer same, i kerb hop every corner practically :woot:, basicly every corner that is part of the short circuit (from the S's to the straight) is where i am destroying my alignment... especially top of the hill over the apex and the last corner get the inside wheels over the kerb on the grass and pulls you through the corner... :D that screwed me over once though :) haha
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
