Superlap Timeattack Is Ago!
  • Replies 1.9k
Your on the money there phunky,,,no need for hi octane "sparco" expensive ones. Cheap crap supercheap and the like are cool,,but they have to be bolted as ADZ says as well as with big-arse washers,.,,NO rivets.
Neil
There are two ways to look at it. 1) is grab a cheapie so that you pass scrutineering and hope you dont need it. 2) Grab a more expensive unit just in case you need it.
The cheap ones would not put out my ass hairs after lighting a fart. Those that have had the misfortune of a fire know that the extra dollars are worth it, could be the difference of containing a fire until the big boys arrive on the scene and extinguish the fire
Yea Roy,,,I know where your comimg from buddy,,,but the little one won't put out my ciggy or your arse hairs,,,,are you still lighting your farts mate and by the time the big boys get to the car its maybe kinda all over. Small oil fires are easy but it can turn into a fuel fire which is the one I'm running away from. My car has a bomb which is what all race cars have,,,but this is basically a long winded supersprint.
Neil.
if your cars is on fire drive to the nearest flag marshal
cause at oran..last people you want to rely on are the fire truck at a super sprint
your better off having a wet towel and a cool six pack to watch your car burn then expect them to roll up on time
response at a race day is diffrent though :( thank fcuk
Has anyone got a full extinguishing system in their car? I don't know the name of it, but I'm sure you know what I mean. Pull the cord and fire be gone :(
I've contemplated one, but gather that they're prohibitively expensive.
I could imagine it'd be a royal pain to clean... but worth it to still have a car!
Caroline from CAZracing.com, had her cams approved extinguisher explode on the weekend while driving
and it completely stuffed the interior in her series III zed. Not only the fabric but the electronics aswell. :D Carry a fire blanket instead. :banana:
sorry but I can't see any 1kg, 2kg or 3kg making any difference to a decent size fire. there is a reason commercial ones (and the marshal's ones) start at 20kg. Its nice to have but I will be too busy getting out of the car when its on fire to focus on grabbing the 3x .9kg ones in my car.
When i had mine i actually got out, casually opened the bonnet once the marshalls arrived, as i found out too late the mechanic had removed my extinguisher for his car :banana: LOL 2004 was a tough year for my car :D
Some low-life theiving mongrel stole our racecar trailer last night...ahh well good thing our Superlap car is road registered, has full interior, A/C, heaters, stereo etc and runs on BP98...Looks like we will be driving it to and from the event.
Saw all the trophy's today...very nice...
Edited by DiRTgarage
lol im pretty sure every car ive raced had the above
i even keep the spare tyre in... just incase it needs a change mid track
bp98 was hard to find back in 2002 though so ill give ya that.. posh arse 98 octaine
get a 31 you superlap fools!
BTW, our Lotus Elise HPE (Honda Powered Elise) is road registered and uses a STOCK JDM K20a Honda from a wreck with a 7psi Jackson Racing supercharger. The car has passed emissions tests like this and is fully engineered. We have now conevrted 12 Lotuses to Honda power and are allowed to run in ProdSports and Aust GT. Might even drive the car to the track on the road tyres. Is there a competeitors cruise that gets there in time??
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
