Hey if Lofty can do 1.17's in his NA 2 litre Toyota Starlet in IPRA form on crap controlled Yokies, why couldn't a car with alot more freedoms and HP/PS/KW go alot faster :D
The most important factor, TALENT. Unfortunately money can't buy it. :)
  • Replies 1.9k
Here is some in car footage from my mates street registered 400hp s14 at Oran park GP
This car does 1.07's at wakefield (old surface). Flat 48's around Oran South and a touch under 1.20 around GP.
This car is running semi's (RE55s).
This car is a consistent front runner and class winner in the Multi Club Supersprint Series in NSW.
I would be very surprised if a street registered car on street tyres could do 1.18 around GP.
Edited by blacksx
Was it you who bought my Brembo's and rotors?
Superlap will be full of surprises!!!!!
What times does this car do around Eeastern Creek???
That's very impressive, street registered rwd 2 litre punching out those times, must be a great steerer too!!!!
Troy (aka Roy) has some stiff competition!!!!
But Troy's racing "twoogle" :laugh:
got a spare pair of -5's hanging around?
JAGR33,
The car in the video is consistently quick. But there is a lot of road registered car's doing similar times.
This car will not be entering superlap. As it is pointless trying to push a 200sx on street tyres around a race track.
Unless it's a drift event which it clearly isn't. These car's need semi's to go quick.
JAGR33,
He should still enter it, will be a great event who cares if there are faster cars out there???
Anyway, still impressive in what your mate has done.. :laugh:
JAGR33,
That S14 looks very well behaved for 400hp! Steerer looks smooth and is on the ball doing those times.
JAG, if you guys did EC as often as you have Sandown/PI etc i suspect you would all be doing around 1:42 to 1:44s. I think that EC is a pretty technical track compared to some down here in Vic. I really need to run my car again on some NSW tracks, never ran on any of them with semis and the TD06 :laugh:
You would really needs 18s on a rwd car in teh Clubsprint class. The extra diam and lower profile would have to help a car on street tyres.
Guest
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
