  • Replies 1.9k
Yes that is correct BOZ22N
What is the chance of changing this rule. It doesn't really make sense.
Clubman should be allowed to run the tyre list supplied by CAMS for safety reasons. A super fast car without good tyres is like a super fast car with bad brakes.
DANGEROUS !!
Why don't you put a vote out to all the entrants in clubman and take the majority of votes as the basis for the rule???
DANGEROUS !!
well the thinking is the super fast car should be in open then. and in that case they can run any of those semis on the list...
super fast = open = semis
not so fast = club = treadwear over 100 rating
:down:
DANGEROUS !!
If you car is "super fast" then it should be in the Open Class.
If you are concerned with safety then you are quite free to run an "R" tyre in the Open Class.
No one is forcing you to run road tyres, it's 100% your choice.
Cheers
Gary
Just a question regarding body modification in the Clubman class.
Are FRB wide guards allowed ? YES
Are FRB/Carbon doors allowed ? NO
Are Lexan/Speed glass windows allowed ? NO
Cheers
-Nathan
Guest
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....🤣) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
    • R33 with RB26 seems to go off of learned voltage for idle. Seemed like whatever the baseline voltage was once ECU first gains power will be the idle voltage. With ignition on unplug/replugging the TPS would relearn the idle TPS voltage.
    • Have you confirmed the 2 pin coolant temp sensor on the motor is working properly? I've had a very similar issue when I forgot to plug mine back in many years ago.
    • Ok interesting i guess ill wait till using a manual gauge before making assumptions.
