  • Replies 1.9k
Do the rules let you run retreads
hahaha.
for a second I thought it said does the rules let you run retards. and I was going to say yeah of course they do, fatz and john have already said they are in....
the man has a point about john!
Gold Beer Bitch two birds with the one rock. fatz on the back foot this time.
I know I have to get up earlier in the morning to out wit the half wits..
OK lads I have organised Oran Park GP
Warm up for this event has been organised. Is on the 5th June on the GP circuit.
The event has nothing to do with Superlap but I thought all of you who are keen to get some advice on lines, set up etc might want to come on out.
The cost is around the $300 and is run through Ian Luff Motivation Australia. The cost will be well worth it if you are wanting some great advice on how to go faster etc
Trainers are still yet to be confirmed but will probably include Luffy, Ben Porter (Current National Formula Vee Champ). Ian Dyk (Formula Ford, Carrera Cup, Australian A1 GP Driver) and myself.
I am trying to organise a discount for those on this forum.
I cannot respond to PM's for some reason but do not hesitate to call me for further info if needed 0412 574 010
I am away again this week doing driver training in Perth and Queensland so will not be able to respond to questions during the week that much via the forum.
Cheers
Cheers
I should be in pending a quick 1200k's run in on the new motor which ill be doing after work everyday - love oldpac!
I will be INNNN for the 5th and a Thursday. I need some help. There is your In Jason.......
I went to Wakey yesterday with new Bilstien and 1 5.79 and felt good although I messed up with toe settings in rear as unstable unloaded under brakes at end of the straight and the car was walking around a bit in the rear, and not good. Got to try stuff though. Have been lightening the car today a bit more so I can get closer to those pesky QLD boys.
do you ever do any work any more johhny or are you full time zed development and track testing now?
you must be the best customer you've ever had! just don't give yourself a bill as you may give yourself a little heart attack and send yourself broke.
Guest
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
    • Oh yeah, always always always turn over an engine by hand first.
    • So by that logic, an insanely expensive GTR for $200k+ is quite cheap, at 12% of Sydney's median house price compared to over 50% when a GTR was new...
    • Apologies... thought i had outlined it... Cheers for the response, I'll get a nipple sorted out for this.
    • lol thanks for the pics but some arrows might have helped for context. If you mean the bit I've badly traced in red, that is a PITA vacuum signal for the power steering pump, only R34 GTT was "lucky" enough to get it. Yes you will need a nipple of the same size somewhere in the intake between the air filter and the throttle or the power steering idle up will not work correctly
