Hey giant I have not seen the article, but Ian told me about it and follows the theme I have been telling Ian about this event having similarities of vision and challenges like that great movie, Field Of Dreams. Now the sign, Build It And They WILL come, which is what the heading is in Fast Fours. Ian said he still has not seen the movie or mentioned it to Fast Fours???
Edited by Boosted Zed
  • Replies 1.9k
kinda off topic - anyone else doing the june 5th day with John?
Sorry buddy no can do I am saving some more coin so I can get SK's GB suspension set up. So I won鈥檛 have the car ready in time :starwars: .
If only it was around the same time as the SAU track day.
I might have to come for a watch though.
Are you going?
Hey Jas, just don't crash!!!
47 people confirmed for the 5th June at Oran GP. Good to see a number of people coming out before the big one on 5th July.
Edited by Bozman1
How come your not driving johny. Whats goin on are ya a bit worried about these GTRs lol.
i heard you got the times down at WP too!
New shocks and springs, not bad for a first up guess :w00t:
I have a new rear swaybar underway for him as well.
Plenty of fun still to be had.
Cheers
Gary
bloody hell gary where's the fun in that!! :)
he needs to tape down his boost button !!, him and i had a great drag race the other day, really cool.
I get my jollies from suspension, more power is OK because it gets me to the next corner faster where all the fun is >_<
Cheers
Gary
unfortunately I've come across a spot of a cash-flow problem, and as a result my motorsport hobby is on hold :) and my track car is for sale (see link in sig) :P
I don't know a cheaper way to get these kind of lap times - Wakefield 1:07.40, Mt Cotton 46.33 (under IPRA record), Conrod Supersprint 49.47
Not too late for someone to snap it up and enter Superlap...
Looks like a great car. Shame it wont be there. I know your pain regarding $$$. I am selling all the gear i have been accumulating for my car engine and drivetrain wise as i am chasing some dollars OS whilst on holidays. Though i think i am going to stop short of selling the car, but still undecided. Your car would be a good buy, hell cool and quick
You do know there are turns involved.
Just kidding it will be good to have the car there.
Of all the drag passes ive ever done (29 total), ive still done many more laps than that of Oran Park. I did have a life before straight line racing.
We could have entered in Clubsprint as our car is more than eligible but we thought it would be better in opens...just like football really, no point running around in reserve grade when a 1st grade spot is available.
Im sure we will have a competitive car and team. My sheepstation is not up for grabs so its all ok.
Edited by DiRTgarage
haha glad I'm not the only 1 that didn't pick it!
Fark, ok, do i get a second guess? Garry Wilmington? LOL my friend wanted to know who did the V8 laps at Wakefield and i was like "Garry Wilmington..." then i realised he probably doesnt do it anymore...then thought Ex Supercar/Touring Car driver :)
Guest
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
