  • Replies 1.9k
I was out there on Sunday afternoon and it was perfect conditions, 19C sunny day no wind.
Far out these things are fast and here is the official times?
Natsoft
I did not get to see these cars and one is Elise Bozman and how do they go so fast? There was a yellow Camano Sports sedan which was the toughest looking thing I have seen at the track and he only did a 1 34. Tube frame fibreglass front end, massive aero and super low roof height and massive slicks with big chev in middle of the car.
Take off the slicks and giants car is much lighter and better suspension etc than when it was there last and ran 1 min 40 last year, and mine is much faster too. I last ran there nearly two years ago and did a 1 43.5. It will still be a big challenge though, as times under 1 min 40 for example even a second is heaps, and THANKS Bozzo.
  Bozman1 said:
OK the bar has just been raised for the 5th July!!!!!
Just had a look at the entries and noticed Mackie and Lucas have entered in the exiges!!!!!!!!!!
Peter Lucas just did a 1.34 around the creek on the weekend, while Tim Mackie did a 1.37!!!!!!!
So Lucas is 5 seconds faster than Berry around the creek and 9 seconds faster than Penlington.
Yes these times were done on slicks. These are proper race cars that have entered and are able to run in open. We are all up sh!t creek.
Awesome! IS the specs of the 1:34 and 1:37 cars the same? Im guessing that the 1:34 is the ex-European GT3 Exige or similar etc?
how did they do in the race? is it possible they f**ked the timing? it's happend before many a time. cause bill pye may be just a rich pig farmer but he doesn't mess about. and i would be surprised to see him in his cup car 4 and a half seconds off the pace. I have to say though peter lucas has really bought things on a long way in the last few years. when we ran robs car in prod sports the first 8 or so spots were always filled by 996 cup cars with the few lotus way down the back a fair way off the pace. though I'm guessing peter has upgraded machinery too as he wasn't in A class before in the lotus he was running.
  Beer Baron said:
nup, it must be right. he was doing 1:36s in the race. very impressive. :blink: the michelein slicks are a good thing too.
At least these things are not aloud to race and big balls or what??? Sorry coud be female drivers??? NOT>........
http://www.youtube.com/watch?v=bf3cJRkeEqE
  Merli said:
All three Elise models on the Lotus website (Elise S, Elise R and Elise SC) are specced with 1.8L engines...
I saw at lotus that sounds similar to this at wakefield late last year. It had an s2000 motor supercharged.
Do they qualify for superlap given they have had a transplant?
I think you will find that they are a K20 front wheel drive engine and gearbox as found in Integra and Civic Type R's.
Cheers
Gary
with turbos on them too I'm guessing???
how does that fit into prod sports? I always thought they had to run the original engine? Marque sports was the "anything goes" category for sports cars... guess it must have changed...
Edited by hrd-hr30
  nfi said:
That would be it :P Thanks Gary.
Especially given the standard engine orientation (east west).
They have alloy Honda block and whole car weighs about as much as a big motorbike? No not really but silly light, as in 700kg or less I believe and supercharged not turbo. I might think different about supercharged engines now.
Rather then something that has been bolted together in a backyard i would suggest they are a race derivative of the Exige from one of the European GT3 series. Here are some specs of one i have saved in my favourites :D
- Toyota 1.8 2ZZZ Charge-cooled and supercharged 320bhp
- Dry sump
- Hewland PCT 6 Speed Sequential Transmission (flat shift)
- Limited Slip Differential
- Switchable Traction Control
- 2007 Wide-body
- Quick Release Carbon Fibre Front and Rear Clams and Rear Wing
- Air Jack System
- Digital Dash
- 6-point FIA Approved Roll Cage
- Removeable Steering Wheel
- FIA and HANS Approved Recaro Seat and Race Harness
- Ohlins 4-Way TTX Dampers
- Aluminium Uprights
- AP Twin Master Cylinder System with Dial Bias Adjuster
- 6-Pot AP Front Brake Callipers
- Centre Nut Hubs
- Lotus Sport 5 Spoke Alloy Wheels (10 Inch Rear Wheels)
If i have guessed right then there shouldnt be any real surprise that the thing is as quick as it is
Guest
    • In many cases, aftermarket dump pipe inlet flanges don't properly align with the outlet of the turbine housing, as they were designed to fit within the constraints of a 3-inch pipe. When an oversized wastegate flapper valve is installed, it can interfere with the dump pipe flange. A bit of die-grinding usually resolves this issue. Additionally, the actuator must be preloaded, otherwise, the flapper valve may rattle. The stock wastegate also tends to open too early, so upgrading to a wastegate actuator with a stiffer spring can improve boost response.
    • Are you referring to the common front u-joint + rear CV setup I see sold everywhere? I have a front + rear CV driveshaft on order but if this thing is going to bind I'm just going to leave it as shelf art.
    • They are real good. Big central grooves, sticky compound. I have no fears in the wet. Except for the first couple of miles where you wouldn't count on them to have any warmth in them yet.
    • My favourite LOL is when I see a nice car with $5-10k worth of fancy pants rims, but, they are running on some cheapy spec tyres And as for running semi slicks on a daily that might get caught in the rain, yeap, been there, done that, won't do it ever again, aqua planning going 110kph on a straight bit of Hwy with the Mrs in the car makes you think hard about your life decisions and tyre choices
