  • Replies 1.9k
:D hehe. it's in the space in my engine bay where the engine should be! never fear, I am trying to sort something out this week. and if it doesn't get sorted I will happily offer my services as a pro driver (or saboteur) to anyone who needs me.
It would be a shame for people to think I am all talk. when it should be known that I am all man.
i give no shit for spelling!
i should enter... if my car is running this weekend i might
or barron can lend me his!
hint hint
we talk at the pub thursday!
yep, asking me when i'm smashed is the best chance you have...
troy is right, I am old school irish, not like you faggoty new school irish.
*(only those who watch dennis leary in rescue me need apply)
Roy, I dont have yours yet either...
I post tripe on internet car forums, i dont actually drive my car :thumbsup: Would love to enter, but have some other priorities at the moment that means my car is parked at present. Though since a friend has just had some dramas this past weekend, he may not be needing my suspension for the event which means one piece of the puzzle has been found :worship:
i know what happend there. you tried the ol reach around gear shift action but fked it up and next thing ya know you're facing the wrong way. need more practice pete.
here's pete doing it backwards earlier. including very cheesy speedweek commentary. back before drifting became a sport. if indeed it ever did
http://www.hgeconsulting.com.au/backitin.wmv careful if anyone in the world still has dial up its 21mb
and before you ask, yes i am just whoring and not entering this time around :D
yea everyone loves skidz
especially me
as for drifting i love it when the kidss come up to me as ask if i drift
telling them i ran the frist drift day in nsw is gold....their stunned looks a always make me smile
i just love how in the photo i actually lost control at turn one but only spun out at turn 9...
yea baby! even better is i borrowed those tyres form a mate who when i gave them back on the belts was not impressed!
Guest
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
