  • Replies 1.9k
Chris, you are welcome mate. Sorry I could not catch up with you again this afternoon. I was glad that you got George Miedecke in the car with you as well to give you some help.
I thought it was an awesome day for learning. Slippery as anything in the morning, and dry in the afternoon. I think you left just before the GT Falcon went into the wall coming onto the straight. An R34 GTR just tagged the wall trying to miss him. That pretty much finished the day.
Ah crap, thats no good at all :)
the GT - was it the yellow XY?
And which GTR....not the NUR......?
But yeah, John - loved it mate!! George did a top job too! Can you pass that on to him for me please mate?
Cheers!
Yep the yellow GT. And yes caused by the oil slick coming out of the back.
I was actually in the passenger with sam in her SP23 and the GT went past with oil coming out the back.I said to her, pull in so I can pull the GT in because somebody is going to crash.
I pulled into the pits and was waiting for him to come down the main straight so I could point the 'finger' at him .....and next boom. He was about 300 metres short of me!!!!!!
No it was the blue R34. Not much damage at all.
Brad, your car is awesome. Would love to see what times it would do on a clear track. Don't get me tempted :)
so...back to the discussion from page 6. what is the winning lap time going to be. I still say 1.10 or maybe 1.11
boz are you still betting 1.12? what is the quickest you have been around there in a skyline?
Well now that the exiges have entered..........I think they will do 11's or 12's. I think the quickest I have done is a 14, in a restricted GTR. I don't think any GTR will do a 10 or 11 unless they are on a slick. It does not matter how much power you have, it still has to go through 'R' compounds. My opinion anyway :)
I am pretty sure the quickest exige does a 9 on slicks.
So yes my money is on the exiges :D
I know it is on the Superlap web site somewhere, but for us dummies how about a link on the Home page that tells everyone who is running without searching for an obscure link somewhere in the text?
Cheers
Gary
Brad, your car is awesome. Would love to see what times it would do on a clear track. Don't get me tempted :P
He had a few moments when I was watching that 34.
Thanks Boz, its always good to get someone elses oppinion. Next timed day its your steer on slicks.
Guest
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
