We were going to race the drag car but the deal on the supply of brakes we made with you was not fufilled.
Yeh, oops, so much for selling them. They are still sitting here :P
2nd fastest :)
LOL, if we are talking drag racing my car wouldnt even be the quickest silver R32 GTSt with Feb 92 build plate running a TD06 on 17" weds :banana: But on a circuit it might be, maybe....if you dont look too hard :)
Team NSW needs to lift their games. We lost the Super 14s, the second State of Origin , well :banana: We are due for a sporting win.
I still say when drunk i have great QC control of stale muffins at the 711 accross the road from Sydney City RSL :)
  • Replies 1.9k
You can use them if you want to buy replacement 340mm rotors, they are cactus. The 324mm gear is fine but wont wont be much help to you or any decent powered GTR:(
Dirtgarage anyone can go in a straight line.
Hey Jason I could drive your car if you want or Roy but I think he is taken??
i want the garage next to them. then we can charge for seats to watch. this should be fun.
We can certainly turn it on in the pits....at one event we even stripped and rebuilt the gearbox between qualifying rounds...much to the amazement of our knuckledragging opponents (V8 brigade). Who are you anyway? (not being rude)
Yes John, anyone can go in a straight line while sober...
Edited by DiRTgarage
stretch is your worst nightmare. he's called stretch cause his arms are 6ft long like the rubber man. he has been known to pull alongside you on the straight and use his super long freak arms to reach into your cockpit and turn your engine off or give you a purple nurple (very painful at 200km/h). it just depends on what kind of mood he's in as to which punishment you get. look out I say.
Hey Troy, what are the replacement rotors worth for the 340mm's?
Too much, better off grabbing some CSC 343mm compete with hats and startign again with a local supply of rotors
Ok, something that hasnt been touched on how many blokes are going to bin it trying to be the STAR in a reasonably priced car? Tryign to prove they can go quicker with less :D I know i am top shelf Blue Label stuff when it comes to trying to hard and crashing and burning
Ill go you halves
pi55 off steve...your bad luck at Oran...come near our pit and ill Voodoo doll you with a 10" flat blade screwdriver.
OK Roy...yes we have a Superfast driver...but our car is full weight (death metal will be blaring out of the on board stezza) factory brakes, laggy, and me twirling the spanners. Im sure no one is handicapped that badly.
lol, im going to set up a fold out seat and an esky full of beers in your garage then
Richard stop giving all my secrets away.
i was going to pull aside john and do that , now ill have to think something else .
sorry mate... :P
wait a minute! by crikey I've got it. pull up to him under brakes then hit his 'push to pass' button mid-corner. effectively making it a 'push to spin off' button instead. Ross Brawn has nothing on my strategy wise...
John didnt you just watch jacobson's drag run!! didnt look like a straight line to me
Yep I did and that was squirming the full track and a handful, and obviously quick. Got bumper bars if goes all wrong though. Still nothing compared to looking at the Tasman sea at Phillip Island 7,500 rpm in 5th and no parachute.
Edited by Boosted Zed
Your in a boat...what does it matter?
Guest
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
    • At this point I'm just 'hoping' it's the turbo seals. I did speak to someone who said it's normal for these turbos to have a bit of axial play? Not gonna lie I've never checked a turbo for axial play before but you could hear it tapping a bit as I moved it back and forth. Surely that's too much? My theory is (could be completely wrong), bad axial play, worn bearings, bad seals, oil into dump/compressor side, burns in exhaust = blue smoke. On a timing belt related note, my crank pulley was missing that front plate that sits in front of the timing belt. It's that metal round plate. It did have the rear one, and the woodruff keys are in the crank which was nice. Can anyone confirm if the NEO det engine has a front plate, im sure it would to protect the front of the timing belt or something. Water pumps...the pump I got was an NPW (yes grill me if I should've got a genuine one lol). It has a smooth mating surface, kit came with a pretty pathetic looking paper gasket. Do I need to use any RTV or just trust the gasket will work because its a smooth mating surface? Cheers legends have a good Easter break!
    • Cheers man, I thought the same.   Bit of an update on it all. It was definitely blue smoke, not grey after all. It didn't really smell oily but it was blue after all. Also puffing just the smallest amount on idle with no throttle.   I ended up pulling the intake and exhaust off and there was around 3mm of axial play on the turbo shaft. So I figured we'll that's buggered and sent it off to get hi-flowed at hypergear. Haven't got it back yet.   I haven't compression tested it yet. Had a look in the cylinder and cylinder 1 spark plug, looked a bit sooty but not oily. Then I've just started doing my timing belt because it's age is unknown.
    • In that case it is probably stock. It lives in the navigator side footwell behind the plastic trim just in front of the a pillar.
