  • Replies 1.9k
well, because gtrs can never be beaten of course!
ryan, do you laugh every time your car comes on boost?
Yer, its pritty cool a ! Maybe you should sell the gtr and i will help you with a very nice 25 set up. :D
Thanks guys :laugh:
Somethings wrong up top, ill find out exactly what quite soon. There was an incident during the build and i have a feeling that thats the reason its failed - which is good as its not my fault. The motor had been blowing white smoke since i picked it up, but only after a decent rev past 5000rpm, i thought it was the tune (or lack of) but now its pretty clear i was wrong, there was something wrong in there from when i got it
Dry sump fittings are on the engine but its still running a JUN pump (sump setup will be a scavenger setup to a tank in the boot that feeds back to the pickup, so it still uses the JUN pump but flow to the pump wont be an issue, so its slightly different to a normal dry sump :laugh: )
Dam those Lotuses are quick. I think on the day giant will be in the running with both on R compound tyres, and giants supper soft ones. Can't see how new slicks are similar to R compound though?
I went to Wakey on Sat for SAU track day, freezing day about 9c and windy and could not get there until after 2pm due to tow car Commy doing an alternator that morning and long story. Bit of mud on the tack and not good for grip as so cold tracktemps and rain that night and old tyres, bla bla bla managed a 1 min 5.49 a PB, and I was impressed until I put it in perspective with this pesky Lotus, and giant would do this with one flat tyre. Still doing more weight reduction and more power prior to the BIG day but budget does not allow for dog box yet, so will be running the stock gear box still. At least we will look good coming 3rd or 4th or 5th or..................
Dirtgarge thieving p...icks, I hate thieves and unfortunately trailers are hot property. Got a pic of what it looked like, never know small world and if unique it might show up one day at a track or on the road going somewhere.
Thanks guys :)
Dry sump fittings are on the engine but its still running a JUN pump (sump setup will be a scavenger setup to a tank in the boot that feeds back to the pickup, so it still uses the JUN pump but flow to the pump wont be an issue, so its slightly different to a normal dry sump :) )
I cannot believe im reading this....
Send it up if you want it done right Steveo....ill give you a student concession on fixing the build. I know of another smoky GTR engine build that had a little something go wrong in the top end too. Got two monster builds on at the moment that will take my time up but ring me if you need any assistance.
John, quick question - why do you keep posting photos of your zed lol :)
Steve - sucks mate, really does suck and I feel for ya mate :)
Here's a thought...how bout you enter club sprint class in the poopra?
Hi Mr Mackie
Don't try and tell us the Lotus is a cheap build :)
Super cool cars which I just love driving.
I heard a rumuor today that Peter Lucas is worried that he may not be fast enough ( only 11's on slicks on the weekend) and is thinking of getting Bargs or Luffy to drive the car at superlap :)
The GT3 Lotus did a 1.09 with Luffy at the wheel, and he thinks it may do a 1.08 (on slicks). That car would never be that fast on R compound :)
I think Peter should drive his car at superlap to give us a chance on the day.
Will be an awesome day. Looking forward to catching up :)
Edited by Bozman1
Hi John,
Well I'm sure our car was a lot cheaper than most of the car in superlap :)
I have no doubt that Peter and Tim would have got into the 1:09s if we put new slicks on. We were both running on well used tyres and new ones are worth 2 seconds easy. Which is why I am hoping that the new R tyres will see us on similar pace to last weekend. See you at Oran!
Hi John,
Our car was 30K...but then broke the world record for labour charges for a GTR street engine build (no, unfortunately we didn't build this one) So yes you car may be cheaper than ours...hehe
Edited by DiRTgarage
I wouldn't be relying on it, can't see how a used slick would have the same grip levels as a new R compound tyre.
Anyway, go-karts shouldn't be allowed at superlap, how are you supposed to compete against a 800kg car!!!! :D
It's amazing that a GT-R is exactly double that weight.
Anyhow, Teh GT-R can neva lose!!!!!!!!!!!!!!! :)
Guest
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
