  • Replies 1.9k
Hey the drag racing 'smack talk' threads are some of the most light hearted and amusing on here. You roundy roundy boys are always in reading them.
But yes personal insults are a bit low and feel a tad of regret for stooping that low. Sorry again JP
Where were you Roy? I was still hard charging after 3 am Saturday night....and that was with next to no sleep Friday night. Bit hard to have a big night when your almost staying in the outback.
Me a warning, are you a moderator now, far out. Sorry if I got it wrong and so I take it RedRacing is registered business and licensed with MVRA, how many partners do you have?
If you throw unwarranted dirt in life you just lose ground yourself. Be friends.
We trade under a PTY LTD as its been one that we have had registered for quite some time. There is 4 of us if you must know...Kel is our licensed engine reconditioner...Glen is our licensed Motor Vehicle repairer (he used to work for your "good mate" Brad at the Toy Shop, a bloke who no longer wants any business dealings with you) David is our signwriter and extra pair of hands (another bloke who no longer wants anything to do with you) and myself.
No im not a moderator as i have no shiny green coloured bar saying 'moderator' under my name.
Give it a rest John...if an apoligy is not good enough and your not man enough to accept it and move on then so be it, if thats the way you want to be. You throw plenty of dirt yourself so maybe you should start to practice what you are preaching.
Edited by DiRTgarage
well you no what they say, when you land at gold Coast airport put your watch back 1 hour & 10 years.
We must all just be a bit more laid back than those southerners hey. :(
P.S DRD-OOF, i love the nurse.
Edited by BezerkR32
Damn QLDers!!
Hey Dirtgarage that Olive branch has got thorns on it. For someone trying to start a business of some sort you are digging a hole for yourself you are throwing so much dirt, and stop digging up guff.
Guest
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
    • Its a well known brand in New Zealand; its a rebrand of the Rhino RAV3.  I don't know what the wiring difference *is* between the rev.1 (installed about 15 years ago) and rev.2; but as you say I would think its reasonable that it uses the same immobiliser relay circuits. I had a look but couldnt see a similar harness; but didnt move things around since I didnt want to mess with it   It was one of AVS well known Authorised Installers; I spoke to AVS themselves about it but theyre unsure hence seeking advice more so from the skyline community who are more familiar with the actual car and its wiring. Im in Auckland; but the installer is on the other side of the city so hes very reluctant to come back to even look at it to confirm something isnt connected into the wrong wire.  I dont want to drop the name since they *did* do a really good job for the most part. Everything is very tidy and he fully replaced all the alarm wiring, all the sensors, the wiring to the door motors, installed a switch which was never installed in the first place...really happy with the alarm install itself..just not this one issue. We all make mistakes, if it is the alarm, I just want my fuel pump getting proper switched, fused, power as it was; without having to shell out for an auto electrician to switch a wire and tell me it was the alarm.
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
