absolutely sure!! (ahh correction s2000 engine ) :D
also still give a thousand bucks if you fit the engine above to a gtr and it goes out a the circuit and beats and RB powered gtr , becuase it would be well worth seeing!!!!!!!!
Well Stephan Papadakis is no longer driving the 6 second Civic so ...
Trade the R32 GT-R for the AEM Civic ...
Transplant engine into R35 ...
VOILA !
:P
  • Replies 1.9k
Hi Peddler this no doubt going to be a contender. As long as it gets the power down, as it will need some flared guards and decent rubber and suspension and brakes etc, and you know.
Dont worry John, thats why things are taking a little longer than expected becuase we want to make sure that it turns and stops the way we want it to as well as importantly put the power down
DAMN YOU LIGHT WEIGHT SONS OF BIT#$ES!! Damn you to hell :P
Actually will be really cool to see some of these cars in action!! can't wait
hehe I remember someone saying that to me a few years ago when i told them of this project.
On the flip side i wonder how the lotus would go with RB power?
Would the extra weight of the iron block rb be too much for the lightweight to carry.
The engines run east-west in the Exige ...
And you probably should stop giving those boys anymore bad ideas ... they are already quick enough as it is :P
Hey Russ just get that R34 down to around the 11-1200kg mark and shouldnt be a drama knocking of those pesky lightweights as we all know deep down (even Jamie) RB power without the weight handycap will rule supreme.
Why would you put such a heavy PoS in a Lotus? I've thought of putting a worked fwd SR20 in an Elise but I don't know if it would be better than a Honda K20A.
What about an Elise with a Viper V10:
DAMN YOU LIGHT WEIGHT SONS OF BIT#$ES!! Damn you to hell :D
don't worry mate, my car won't be troubling you front runners at all! just doesn't have the development in suspension and steering to really cut it. and 230rwkw probably isn't quite enough for about 900kg of car either. nor is the 4 turns lock to lock steering really up to those 230rwkw in such a short wheelbase with leaf springs trying to put that power down!
Superlap at Oran Park really got me motivated about this car again. Its just been sitting around un-used since the Australian Hillclimb Championships last november until now.
Thats awsome Harry... get rid of that Supra and put your time into the 1200!!!
1 out of 2 aint bad i guess. The rb may be heavy but a pos it most certainly isnt.That such high horsepower can be extracted reasonably reliably from as little as 2 and a half litres is quite stunning really.
Now Lotus on the other hand needs their arse rheaming for using such a slow pos engine in the first place.
I'm just saying all this because I've converted to the dark side Daz :P
And it's to get over the psychological trauma incurred when I sold the Land barge :D
PS. Tell Annie to pull her finger out and get back on track :action-smiley-069:
Hey Russ you are famous again, check this link and website about Superlap. Lots about the R35 GTR, and this is a zed owner and Z fans web site.
SUPERLAP
Edited by Boosted Zed
I LOVE 1200 Coupes!
And only because I am wierd, i have often considered how long a 20B and weight of a 20B vs a Nissan 4? A 20B with relatively small GT series turbo would be a torquey and capable engine in a little coupe :)
Its not wierd, I fantasise about that sort of stuff too, regularly, a 20B 1200 coupe would be awesome Troy, however they do pretty fine with the 'small block' 13B in them as well :rofl:
Good to know there is a few 1200 coupe fans here, unfortunately mine is only built for straight lines!!
hey guys, what is considered to be a good power to weight ratio? i am looking at the 900-1000kg and 350kw, i know that handling plays the larger part but is this in the ballpark?
If you can put together a 900kg car with double wishbones all around you will have a very strong potential. both the front running gtrs would be 300+kg heavier.
And if you mean 350rwkw then potential will put it in the top 5 of this field I think.
shit, just need someone who can drive lol.
this is my light weight powerplant. hopefully can provide the goods. i know its missing a few cams, but its got a few extra cylinders.
Edited by BezerkR32
Guest
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
