  • Replies 54
didn't they just add another $70 to registration???
now they want to go and add $50 for inspections???!!! F'kin stupid!
thats and extra $130 added to rego this year alone!
if it keeps going up like this im going to have to start dealing drugs and pimping schoolgirls to be able to keep my car on the road.
I see it as a budget gone wrong for them and they need more money so they put up prices and add in you laws to make that bit extra money for the community. But who sees the money?
If the gov cut back on tax's etc and allowed the common Australian to have a few $ in the bank I reckon that would have a greater impact on the economy by cutting down on crime, higher employment due to people being able to buy item's, health also were people might even be able to have priv health cov.
Way of life would be better and happier. But they need money for $120 toilet paper and car's and trip's and other bull shit.
If there was a person running for parliment who was to give back to the community what is expected I vote for that person. Anyone up for it?
I would vote for anyone that ran under the premise of cleaning up the system.
Unfortunately, it never works out like that. Eventually they all end up forgetting why they are there and become self serving.
how hard is it to find some lame excuse for spending someone elses money? Not very.
U guys are funny :)
PH was a racist selfish pig in politic. I got no idea wat you are on about here :)
BTW My blood boiled since when I was robbed of 10kph on the street where I had no right to vote for it at all :D
The excuses given were full of BS with lack of any evidence to fool the general public. The only ways to reduce mortality/morbidity/car accident are to reduce tax on car and car accessories and better maintenance of the road. This will
1. allows more safer cars on the road
2. reduce braking distance
3. safer roads
Damn cvnning government.
Now, who want to vote for me?
Only j/k :)
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
