Results From Our T88 Setup!
600hp
 Share
Hey guys for those that may want to know.
We made 360awkw on 15 psi, and on 22 psi we made 450awkw.
I was told to bring the car back in a couple of weeks with some new fuel in it.
Then Jim will add some more boost and play with the cam timing as it was reset to zero.
Also I'll stick the 4"exhuast on and see what it makes.
The street exhaust is a 3"cat back.
The power curve is much bigger now and the rev limiter has also been upped to 9k.
Sorry no graph as i didn't bother printing one out as the car will be back there in a couple of weeks.
Also for the people who don't know the T88-33d has a smaller inducer than the T04Z (they are both rated at 750hp)
Jim also added the car should make over 500kw when tuned with more boost and the exhuast is fitted.
Cheers
Interesting indeed.
I had no idea there was a T88 with such a small inducer. Thats very decent power with 260/9.15's. Would be nuts.
Where are you going to get Jim to move the cam timing / power?
Cheers
get jim to overlay our 460kw 20psi run-in graph (BP98) prior to Autosalon Newcastle then post up
response comparison would be interesting
looking good Ben
  • 3 weeks later...
Interesting indeed.
I was concerned that my poncams 260 would be restrictive at that power level. Im running a t0z (1.0 a/r) and hopefully 2bar to reach goal of 650hp atw. Should be back from machine shop next week so not to long to wait and see.
Interesting indeed.
Edited by drgnball34
I know of a certain stock capacity 26 on here that made almost 800rwhp with 260's....
"restrictive" is a relative term.
I agree...a stock rb26 head is capable of flowing almost 1000hp...yes stock cams, valve gear etc.
this lines up well with your example
 Share
    • Little more work!  Did some body work on the rear wheel arches and since the paint was a cheap spray job before figured I’d do something to tide me over until I wrap the car.    Colour might not be everyone’s choice but I like it and it’s only temporary, just hate having primer from the wheel arches standing out.    Keeping an eye out for a decent set of wheels to throw on now. Wheels and tires on the car are junk
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
