  • Replies 745
Think we're going down to the drags for a look, I won't be racing unless money starts to grow on trees and i can fix my car up within a few weeks. Doubt my gearbox will ready by then either. not sure when the black beast will be ready but i don't think that soon, its coming together quicker now though. Until i get my new car I'm staying out of racing for a bit.
Originally posted by fwddriftking
ouch that suck you haven't though about contacting jms at all willo?
I've been keeping an eye on their site but haven't seen any pull type clutches go through. I would assume they can find whatever I want but a lot of other places probably can as well. At this stage I'm thinking about waiting and getting something new, a lot less hassle.
Autobarn. They have a pile of them in the cabinet. I was a pretty technical proceedure but I'll outline the basics for all those wishing to purchase said product.
1) Go into Autobarn.
2) Speak to closest Autobarn employee and say "High Octane 4"
3) Take DVD back to counter.
4) Pay for DVD (or not but I didn't feel like running and I'd like to go back there)
5) Leave.
Any Questions?
Originally posted by digsy_20
actually I am bulk impressed with the Scibyline... It goes hard... He called me from the lap and within a couple of minutes he was at the top of the Mount...
She does what she's told. :/
Here's a photo I took from three weeks ago.
Correct me if I'm wrong (which I probably am) but don't Daikin make some awesome clutches? Although I think they're european.
THere was plenty of High Octane 4 DVD's in Autobarn today about 20 minutes after Squizz was in there too.
Oh and the dude thats been canning Dev's old 33 is in fact Briscoe's sun he's been driving it home every after noon of late. and gods it's sad when he pulls up preparing to drive up his driveway only to sit there chrunching and searching for gears for a few minutes.
I think I saw Fro pulled over last night. Did he get of alright? Or was it major defect time? I hope not. See everyone around.
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
