  • Replies 745
there is a really tll bald eagle with bushy eye brows that just beats everyone up. I think he read the news once I've never taken lsd but trying to think back about the muppets makes me think i must have hit it pretty damn hard between the age of 5 through to 10
Originally posted by Nissan = Good
correct me if i'm wrong but did the two old guys seem a little bit to friendly?
Yoda and Scibes: The untold Drama.
This reviewer knows only too well the pain of love lost and found so it was with a tear in my eye I watched this film. I felt as though the taller of the blad men was a tad stilted and wooden in his acting but in his own quiet way he got his feelings towards Yoda across in a most convincing fashion. The love scene under a car hoist will go down (literally) in the annuls of time as an all time great movie moment.
The trials and triumphs of these two gentlemen (I would hardly call them gentle after the shower scene) really sucks you in and proves there love is more of a long hard slog than just life giving them a shafting.
I give it 4 out of 5 dancing buttocks :shake::shake::shake::shake:
Hey I am still keen to see if anyone is running at the drags...
Rick... what do you reckon think it is the right nice cool weather to run some good times... it is definatly turbo weather at the moment... although a night meet would be awsome at the moment...
I think Sciby should think about entering the Scibyline... we should see what the 2.5 can do before hitting it up with a torque monsta 3 ltr...
Dev... I don't even have to try to talk you into it...
Hopefully my mate with the fully sik SR Stanza should be there... it is getting so quick it's almost sickening... and for the price... ouch... definatly a budget beater... Seen the spotties infront of the intercooler... how much more of a sleeper could you get!!
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
