  • Replies 745
Jus thought I'd let anyone know that the Motokhana in the K-Mart car park in Gladstone is on this Sunday starting from about 9 or 10 am. If anyone wants to come down, let me know. Otherwise enjoy your cruise dudes. It's sounds like it's going to be really good.
It would be awsome to change the cruise from Yeppoon to Gladstone... would anyone be interested in going to Gladdy instead for this Motokhana... it would be interesting... although it is tuff finding enough fuel to get there and back...
tell me what you all think??
or does it stay as a beach run??
Rick do you reckon you could organise the beach boys for a cruise to Gladrock??
Hmm... I really have to do something about my info on www.garagespank.tk
it's just that the plans for it are nothing like what I was going to do to it a couple of months ago... Although atleast it does have a T28 on it... to bad it isn't a S15 turbo... but it still a big upgrade from the CA turbo that was on it...
Actually is anyone interested in rising rate fuel pressure regulators... I want to order in a batch of these AMOS ones... cheap... different... did I mention cheap...
It's just they come from America so if anyone is interested in this great product... pm me or something just cause I want to order in one for myself and one for Phill's GQ patrol... so while I'm at it... should order in bulk... I'll try to get a price put up on that spank website soon... just so if anyone wants one of these cheap regulators they can call me... either that or they can order them in themselves of course...
the trouble with silvias is their independent front end, they just dont have the articulation or cross up. dont get me wrong, there great on road, but its was the wombat holes in the latest "tuff import challenge" where they come unstuck. but i dont know maybe someone out there has bombed one up with a 24in lift and possibly 38in tyres(not rims). but like i said, i just dont know.
Yeah Brocky Cutter I have done extensive modifications to mine and I still lift a wheel going over a gutter... they just don't seem to have the flex of a full bombed "floating"front end skyline...
although silvias always beat them in the uphill climb... It's a tuff decision but air lockers fix the flex problem...
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
