  • Replies 745
Hi everyone I just thought I'd let you know that I made the trip down to Gladstone for the Motokhana but unfortunately it had been cancelled.:) Bugger, but anyway I thought I'd just tell you about an interesting thing I saw. On the way down we went past a group of imports that looked like they were on their way up to Rocky, maybe for the cruise or something else, this was about 12.30. Anyway the group consisted of a few 300's a S13, a few R32 and a few R33. So I was shocked when I was on my way back again at about 2.00 when we past the red 300 with a bick wing heading back again I was like What? Then we cam accross all of the cars pulled over and talking. It looked like they had been pulled over by a cop .:P
So I gotta wonder what they did to still be sitting there over an hour later. I don't know exactly what was happening, but I reckon it would be interesting to find out from anyone who knows.
Yeah the cruise was Awsome... I had a blast and I stuck to the speed limit... most of the time...
There was 3 Gtr's, 2 silvias, 1 33gts-t, 1 32 Gts-t, 1 MX-6, 1 Cordia and a Clubsport... 10 Cars... and it was a blast... there are heaps of photo's getting around and generally we just chatted and had fun... JR you could have added to our crew but I understand that SBS is good watching... speedweek is a top show for a bit of lower budget racing stuff...
And Garth that is too bad about the Motokhana being cancelled... oh well they will just have to have one up here... I am sure all the local imports will be there to have some legal fun... can we drift? or is there a few rules for safetys sake... just it would be awsome to have a few GTR's there, some sideways S13 action... maybe even jay could punt around in the fastest taxi in rocky...
tell us when it is going to be next in rocky and we will put it in the Garage Spank calander... it's definatly on my to do list...
There hasn't been to much tech conversations on here lately so...
This is a discussion and it is open to all with an opinion... state it openly and wisely... don't just say it is... give reasons...
What is better
a three inch Stainless exhaust or a 3 inch mild steel... just I am thinking of upgrading my exhaust and I am wondering about the advantages... it's just with mild steel I could replace my exhaust 3 times for the price of one stainless system... and what if I rip it off or something... maybe the mild steel is the go... can anyone think of any good reasons why flow would be better or is it just wank factor??
Originally posted by sportif
Yeah but the problem with that car is that he has bad blowby and the dipstick has to be held in with a piece of tape. POS!:upurs: [/b]
Yeah valid point,
But that POS as you call it also ran 170rwhp on a pretty hot day.
So what does you 323 run at the wheels. POS.
Man that is a small skyline in your picture dev. That s13 beside it looks pretty small too............. Dan dunno is marge would fit in on the cruises to the beach, would have loved to come down but. Might just have to get even bigger spotties on the front for the roos on the way home. I will have to get mark to hook me up with a pair, like the ones he will get on his ute.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
