  • Replies 745
What about the Mongrels... what did Josh say they were worth?
they are a really good tyre for what they are... and now in 33 x 12.5... they sound good... some new suspension and body blocks and emma's lux would be looking tuff...
when do you get your big rig Brocky Cutter?
Hey Actually here is another topic for this CQ Performance Thread... I was talking to Darren of 180GO fame and I asked him a few questions about brake upgrades for Clubsprints... He told me that I needed to Take off the Metal backing plates for the disc brakes... now I know this seems obvious but is this a good move for a street car... does it protect the rotor more than it matters... what about does it act like a heat sink ( draw heat from the disc) or does it trap in heat?? I think it traps heat, and I personally think if you brake a rotor you are probably doing the wrong thing in your import (eg. 4x4 competition or something)
what do you guys think?
Also he actually recommended Bendix Ultimate Pads... he said if I had the money go with Endless NA-R but otherwise Ultimates are the Go... I thought there would have been heaps of pads better than the old ultimate... but he seemed to think they were really good for the price... so maybe that is something to think about next time you are crying just thinking about the price of big name Jap brake pads.... stick with the old Bendix Ultimate!!
I'm still chasing interested parties for the trip to Brissy at the end of this month... it will be simply awsome with a few cars punting around the track... and don't think your car is to slow... I can show you some video of a stock early pintara thrashing around the track in Panda Colours... it is really open to ANYONE... JR that means your mirage to...
Actually it would be awsome to have enough cars there to have our own bracket (7 cars) on the track... all CQ motorsports fans...
Hey brocky cutter...... are you a rtuckie or sumtin.. coz my dad is a truckie. he has a Kenworth T904. Best one around!....
Wanna know why. its a RICE RIG!!!!!!!
$8000 worth of shinnie stainless steel on it.
and. umm.... Couple of blue neons. on inside and out!.like behind the front grill....
Pioneer Head unit- : Front speakers - Fusion
: Rear Speakers - Alpine
: 10" Pioneer Sub, all amped up by a little pioneer amp.
Oh and a t.v and video player
Hoo roo
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
