  • Replies 745
Originally posted by brocky cutter
heres a Q to whoever, what would be the chances of importin a 4x4 2.4L PETROL hilux(that has nt been slammed on its guts)
and what sort of price, would it involve
R there any good importers in Rocky?
There are importers, but opinions vary. I personally went through a guy in Perth.
No, it's done all by phone and internet.
I rang him, after doing some research and hearing nothing but good, said "I want this", he said "No worries", the next morning, my mailbox was full of cars in the specs I requested, and so I picked and chose. I picked the one I've got now, won it at auction, then it got shipped over here, complianced and I went down to Gold Coast to pick it up. All I had to do was to pay for things and make sure paperwork got where it was going. Was good.
importing 4wds has become more difficult with the new sevs rules. I'm not sure exactly whats eligible but I think its about only the 15 y.o 4wd that are able to be imported readily .... I do know you can;t import cruisers anymore because of their power to weight ratio isn't good enough to fit the rules.
Good Mroning all!, its wednesday mornin. at school. in BCT. ment to be doin a Research Assignment on some country. but. i have already failed this class. and she told me ven if i get an A on this thing i probably still wont pass it. so. stuff it. may as well bludge!!!!!!!! i want to get out of this class..... but i cant.... unless ido a traineeship..... but i dont knwo where i want to go!. so. im stuck her til then.
Well...... i guess ill go chat to somone else in the class.hoo roo
Originally posted by Tyler666
mad. sounds so easy.. but yet. sounds so annoying and hard. and u would have had to wait a while....... what were u driving vbefore ur skyline. and was it your first car????
First car was mum's Mazda 808, which has now become mine again, because my car before the Skyline was a 1988 Suzuki Vitara:
I gave that to the old girl because she couldn't afford to buy a new one...
And the importing isn't annoying or hard. It's very straightfoward. The guy in Perth gave me a good checklist for the process, but yes, had to wait about 6-7 weeks from the moment the bank gave me the money to the moment I snapped the tail out on the first corner.
Originally posted by Nissan = Good
Scibs you going to drag the 33 so you can have a time to compare the performance difference between 2.5L and 3L?
Yeah, I will be. Hopefully I won't destroy anything that will divert funds away from the 3L or new suspension (Which I need more than the 3L). Probably only do about 5-6 runs and call it a day. I want a good idea of what it's capable of, not a destroyed Skyline.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
