  • Replies 745
Hey, spanks jaoshie. and yes., i do mean well. as i just posted in the kaso thread. and i dont mean anything buy it either.. i dont try to be mean at all. i dont know any of you.. mabye if i knew all of you. and you all knew me. youd understand my posts!
Oh well..... ill go back to the sand pit
bye
Hello. (B looks around shyly) Am I allowed in here?
Sorry for anything I might have said yesterday. Just a bit hurt about the friendship drifting apart between Mr Kaos and Mr Spank. Confused about why. Sqizz...if you ever want to tell me why, you know my email.
Mrs K
Mrs K
Hi Mrs. K, yes, you're more than welcome in here... anyone is... it's not like secret club, and it's not Spank HQ or anything.
(The below is not aimed at you, Belinda, it's just a general rant of mine about the current "social" situation)
Friendships change between people, and whatever's happene between Kaos and Squizz, well, that's between those two. As for the rest of us, there seems to be this confusion that "Spank" people (or Spankers, if you prefer) hate "kaos" people. We don't hate them. We get annoyed at stupid comments that get made, that are incorrect, uninformed or just plain lies, and I personally am very disappointed in the attitude of certain people who have turned their backs for unknown reasons and started fabricating stories. We're not bad people. We don't hate you all. We don't hate your cars. CyberPrelude, I want to rub myself up against your Prelude, although I think it could do with a bit more grunt, but still. It's horn. See?
Finally, for all the extra people who feel the need to rant on and tell us all to be friends, there are certain past histories between people that are no business of anyones apart from the parties involved, so don't ask, but it shapes relationships into the way they are.
Not all people get along all the time. That's just the way life is. You can't change it by demanding it and trashtalking and shitstirring don't help the situation, at all. This goes for Kaos and Spankers.
My personal attitude is that I have nothing against Kaos as a whole, and any personal issues I have with individual people are MY issues. *I* will deal with them, if I so choose to.
And no, I don't wish to talk about them, and no, those comments are not some thinly veiled stab at anyone, so please don't flow me with paranoid "What ahve you got against me, man?" comments.
Anyway, the pielady just turned up, have fun y'all.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
