  • Replies 745
Nah, I got a ceramic turbo... the nylons are series 2 R33's.
Jish, don't be talkin' whack about my mother, I'll bust you up, son.
Edit: On the turbo thing, the ceramics will handle up to 14psi before they start coming apart... the nylons are worse, so the story goes... 12-13 being the break point... but some people might get lucky and get a good turbo from a good batch that can handle a bit more... personally I'm not worried about bits going down my exhaust, but VERY worried about bits of shattered impeller blade making their way into my plenum and into the engine. They'd have to make their weay through about 2m of piping and the intercooler... but still... at the cost of the engine, I'd rather not gamble.
Sorry Matt, just editted post as you posted. Read back.
Edit, again: I seem to remember something about ceramics holding and holding and holding and then just letting go with a loud crack, whereas the nylon internals will peel and seperate over a period... dunno how long the period is, but I'd say that as soon as it starts, damage will increase exponentially.
What happens with the engine remains to be seen... that's off in the future, anyway. Changeover will happen... er... when I can afford a few other bits and then sort out the plan of attack. Probably before the end of October.
ah ok ... thought you might use an aftermarket on.e I'm still yet to how well a power fc works with a 3L twin cammer motor ..... I know a lot of people don't think much of the power fc as not every tuner can tune one but i believe give it to a tuner who has a fair knoledge of tuning and has tuned on many many different ecu and they will be able to tune it well. Plus its a damn cheap ecu for one that is closed loop .....
Originally posted by Bling_Bling
Who cares it just all fun that whole idea hey.
Originally posted by pimpspec
We will, its just fun to try and guess what times a car will do.  althouhg last time i had quite a few people tell me that i would do a 13 without adoubt but I never ended up doing one so it was a bit disappointing ......... hmm I better shutup now don't want to have some be disappointed in their car .... anyway guys a 13 second street car is still damn fast and would beat the majority of cars on the street .....
Yeah its great fun, but mind u i also like getting my dick caught in a blender,
By the way guys we are getting a present for geno. I'll buy it and court is going to be my debt collector. Be afraid that bitch scares me. Not posting what we are getting cause i don't want any retard telling him. But we can get it engraved with eveyones name, or just the collective group. Bad news on the keg front too. Damn it just have to drink corona. Those pricks, but hey i'm a survivor as christina says.
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
