  • Replies 745
Jus thought I'd let anyone know that the Motokhana in the K-Mart car park in Gladstone is on this Sunday starting from about 9 or 10 am. If anyone wants to come down, let me know. Otherwise enjoy your cruise dudes. It's sounds like it's going to be really good.
It would be awsome to change the cruise from Yeppoon to Gladstone... would anyone be interested in going to Gladdy instead for this Motokhana... it would be interesting... although it is tuff finding enough fuel to get there and back...
tell me what you all think??
or does it stay as a beach run??
Rick do you reckon you could organise the beach boys for a cruise to Gladrock??
Hmm... I really have to do something about my info on www.garagespank.tk
it's just that the plans for it are nothing like what I was going to do to it a couple of months ago... Although atleast it does have a T28 on it... to bad it isn't a S15 turbo... but it still a big upgrade from the CA turbo that was on it...
Actually is anyone interested in rising rate fuel pressure regulators... I want to order in a batch of these AMOS ones... cheap... different... did I mention cheap...
It's just they come from America so if anyone is interested in this great product... pm me or something just cause I want to order in one for myself and one for Phill's GQ patrol... so while I'm at it... should order in bulk... I'll try to get a price put up on that spank website soon... just so if anyone wants one of these cheap regulators they can call me... either that or they can order them in themselves of course...
the trouble with silvias is their independent front end, they just dont have the articulation or cross up. dont get me wrong, there great on road, but its was the wombat holes in the latest "tuff import challenge" where they come unstuck. but i dont know maybe someone out there has bombed one up with a 24in lift and possibly 38in tyres(not rims). but like i said, i just dont know.
Yeah Brocky Cutter I have done extensive modifications to mine and I still lift a wheel going over a gutter... they just don't seem to have the flex of a full bombed "floating"front end skyline...
although silvias always beat them in the uphill climb... It's a tuff decision but air lockers fix the flex problem...
Guest
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
