  • Replies 745
i was joking remember...... bcoiz. i dont have a car. coz i was joking........
i cleaned my motorbike this sarv....... Joshie.. how much should i sell it for????? and does anyone know how much it costs to put in the paper.lke the "Run it till it sells" thing.?
bye
Originally posted by JR
what would be the suggestion to do with the green neon now? aparently its not legal in the grill. i was thinking of zippy tieing it under neath, then just running the cords up the side then thru the doors? anyone else got any suggestions?
sell it and spend the money building your up your motor so its ready for the sneezer :D ......
Guest
