  • Replies 745
Yea, I missed it would not have minded watching abit of a fight, fights between one guy and a copper abit unfair. Dale got two point for that lauch, the coppers where following him from the Mall the rest of new that but him, good lauch shame about the two point deduction for it.
Guest
