  • Replies 745
Yeah well the main reason we were going out for a play is that phils mate just brought a 308 patrol, but him and phil had other things to do.
Phil was helping his mother move some stuff, was spose to do it on saturday but him and the boys go to busy with his car at our place.
Wades car looks good with the new "front bar" and now a snorkel. Rig
Guest
