could be a low reading dyno. how do other cars go on his dyno.
my old SR20 180 got 151 RWKW with just catback, filter and 15psi. And i had a 1J with same mods got 180RWKW. (EDIT:Both on Dyno dynamics in shootout mode on dyno days)
Well it seems to be one of the Better Workshops for performance cars and Dyno's in Townsville!! They have some pretty good cars in there at the moment!! It's been on there 3 Times now and all come up with 151 Kw's!!!
  • Replies 111
Yeah maybe are you sure
Maybe not
its not their Dyno
Mines been on theirs and pulled 195rwkws
Stockish r34 with some boost
Maybe not
its not their Dyno
Well if yours is a stockish R34 GTT and getting that result then mine should be pulling a little more then 151 being a GTR!
And if you say theres a better workshop i'm listening cause they cant diagnose my problem!! Not many other places to go in townsville! There are some places that i have heard some good and bad about!! Not gunna name them!! But ya pretty much know the performance shops in the Ville!
PMR33 and myself can vouch for how good The guys where you took your car to are
they were that good that when they failed we had to solve the problem ourselves
Well i'm not gunna waste my money for another workshop to tell me and go through the same problems and spend the same ammount of time to tell me exactly what i all ready know! So i'm sticking to the place it is! I have all ready got 8 Hrs of work done for free cause they were chopping and changing stuff on the car to see what it could be so i'm pretty happy actually with them and they do know there stuff there!!
Hey,
Well good luck with this workshop, having a tuned aftermarket ECU (MINES tuned for Japanese standards), 10psi boost, I made 154.4AWKW (pretty hot day but no excuses for the R33 GTR) with a 3inch cat back exhaust, compliance cat, compliance filter (airbox). I think the dump pipes were aftermarket.
However, I did high-flow cat, high flow panel filter, and got a PowerFC and tune and increased the boost to just over 14PSI, about 1bar, and I got 250RWKW.
So without engine management your not doing that bad, and be warned that dyno's do vary quite a bit, other people might get more but different dyno, different temperatures on the day....
I had the same problem when I first got my GTR, drove like an absolute pig. Went to Tilbrooks and came up with about 150rwkw's too. Ended up being a boost leak on the pipe leaving the intercooler. They simply tightened it up and it pulled 207kw's on a car which only has pods, 3 inch cat and exhaust, and running 15PSI with stock ECU and just for the record ran 12.4 in that state.
About 3 years later lost nearly all power once on the freeway, thought a turbine wheel had dropped into the exhaust - ended up being a collapsed cat as per a few previous posts. Put a new exhaust system on and got 218kw's! :D
Have you tried someone else ECU??
Na havent tried running someone else's Ecu!! Not really a fan of buying a 2nd Hand ecu and taking someone elses problems! Thinking of upgrading though to a Power FC But trying to find a New one at a reasonable price is pretty hard!!
mate i had a similar probblem, when i got my car it only made 140kw, the timing was out, fixed the timing and replaced the stock cat and got 222kw
thats with 3.5" exhaust and the restrictor out
Thanks for the Help Mate!
Timing was fine but they added an extra 5 Degrees on it and go an extra 20 Kw but this cam setting aint stock so its just overiding another problem that there!!
They wanna try another ECU but all they have there is haltech, wolf or something like that and some other brands that they can get for overpriced!!! Quoted me Some where between 1200 and 1400 for the Basic Power FC for a 32 GTR when i have seen them on ebay for 950!!!
Since you have a GTR you can actually BUY a PowerFC, it get it in Aus expect to be charged a lot maybe $1500 if off the shelf with warranty.
From Japan, anywhere between $950 and $980 is normal off the forum traders, if its not in stock it can take time, maybe 2-4 weeks but I've heard of some taking much longer.
If you have time look at sites like Greenline or keep watching ebay >_<
79,000kms huh? maybe more like 279,000
rigggggghhhhhht.
my money's on a worn out motor, gearbox, diffs, wheel bearings etc etc sapping what power is left.
Lol!! I know what my Car has mate!!
Thanks for the Advice Mate!
    • Yeah, the latter. No diff should have a centre replaced without checking clearances because its unlikely to be the same as whatever came out. Not that that stops most people just checking a new centre in
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
