  • Replies 111
Luke we are not having a go at you or anything like that man
I just seriously believe these ppl know jack shit about cars (PMR33 will back me up there ) and if you are not happy get a second opinion as to why the car is down on power
If you are happy then good they did a good job for you
Well what else could be the problem if it is down on power???
I have been told everything is Sweet in the car by the mechanic! He said its one of the better GTR's he has ever seen in the shop!
So if there is someone out there that can tell me what else it is thats causing crap power apart from everything that has been checked, cause i will be listening!!
And can some one please tell me the RWKW's on a R32 GTR STOCK Straight out of the Factory back in the 90's!!!
I think someone needs to tell me what the Factory Rear Wheel KW's of a 32 GTR if it was taken straight from the factory floor and put on a DYNO!!!!!!!!!!!!
Claimed factory 206KW's
Actual figures 240KW's
This is at the fly-wheel I am assuming...correct me any one if I am wrong
Loss of power through the drive train etc.......brings you to around 160 kw at the rears...or 140 AWKW.
Wear and tear through age and carbon build up in your exhaust ie pipes,cat and rear muffler
combined with bad oils in your engine/diff/gear box can cause more than a 30% loss in power delivered to the ground.
The figures you stated earlier in this topic...the before figures confirm this.
The figures you got after PFC install and tune bought your power delivery back up to well over a stock motor(new).
Thinking again about your mods.....
I am suspecting your muffler may have a large build up of carbon.
Check your rear muffler.
If it is stock...get it re-conditioned.
Do not get a cannon.
Well it came with a Sheep Dog Exhaust when i Bought it but i did swap it with a Turbosmart Cannon about 2 Years ago. I liked the Look of a Cannon Rather then the oval style with the 3 Inch tip!!!
Still got it though!!!
This is a pic of the exact item!! (Not my pic though)
Loss thru 4wd drive train isn't anywhere near that high, i've seen a few ppl that have done back to back test 2wd vs 4wd on GTRs, lucky to be 10kW difference.
Besides this was already covered early on in the post.
Keep that if it is original...
The mufflers are very hard to find..I should know...have been looking for a GTR33 one for ages.
Luke.......if you have a chance to give it a run in a 1/4 mile drag...pm me your times.....
Just don't fry your clutch to much though....this will be your next mod if you do.
oh i don't think its a Factory Original!!! Just original on it when i bought it 6 years ago!!!
Pretty sure standard R32 RB26's make about 160-170rwkw as standard RB25's make about 130-140rwkw, obviously depending on dyno and in what condition the motor is in. All i know is from knowing quite a few ppl with similar mods on RB26's up here they make about 220-230rwkw with a Power FC, bit more boost and taking out major restrictions such as the exhaust. Now maybe that extra 20rwkw doesn't sound like much but thats around 35-40HP at the engine, hell thats a low of power to just "lose". But maybe its just something like your exhaust isnt that free flowing or your intercooler is a bit filled with oil build up or your engine is just getting a bit old and worn etc.
But hell, if it drives fine and feals fine and you don't really care about getting power out of the car and want just a nice driver, then who really cares, just leave it.
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
