thats about right, dont expect more with optimax or nething, that wont make much difference at all! get it dynods with the pod filter tho! maybe even take the exhaust off see how it goes :D hmm they didnt put u into 3rd gear ? strange, i think it wouldve made abit more power than that if they took it about 140 kph
Not bad! typical factory intake and exhaust though. That's whats producing the trail off in your torque curve. Fix that up and you'd find another 2o+kW. See here how a bit more torque can sweeten the deal up. Looks like hes running it in second too. Not a bad thing but the high the gear the lower the power figure can look, so don't be surprised if another dyno run in another gear gives different figures.
I hand made mine, but you can get good ones made by the shops. I'm just running a 2 1/2" mandrel bent mild steel system with a resonator and a high flow hot-dog style mufler. A system like that shouldn't cost you more than about $250ish. Then with a set of extractors you'd definetly smooth the torwue curve out. Bigger numbers will then come once you start tweaking the cam timing and fuel map. Don't think for a second the factory fuel map is perfect!
My exhaust is loud - it has 2 resinators also..
Ive never takn it for a 1/4 yet
My car has been running like crap for 1/2 a yr so i never botherd.
I took it too a new mechanic a few days ago and he fixed the problem strait away.
No offence, but loud doen't necessarily mean optimum. You can easily optimise back pressure but keep noise levels down. You can also have a really loud exhaust that does little for performance. What did he do to fit its running performance?
My old mechanic made one up for me, but then again he couldnt even fix my car so i dont know how good the design is really
My car used to misfire alot too - and you could aways smell petrol :(
The spark plug gaps where wrong and they were too loose some other stuff that needed adjusting also which i cant remember off the top of my head.
 Share
    • I think throwing the hydraulic power steering system into the trash and converting to electric power steering, e.g. Astra PS pump would solve many issues.
    • so finally had an event i was home for that didn't get rained off or otherwise cancelled to be able to actually drive the car, unfortunately was roll racing which isnt my favourite thing ever but had an awesome night with friends and testing the car out. obviously a huge difference in driving experience with the samsonas although still without flat foot upshifts the ratios are so much nicer and actually has boost into the next gear which was not something i always experienced with the stock gearbox. but of course absolutely loving the sound of the sidepipe and for its downfalls of ruining the car in ever other way it does sound awesome at the track.   had some weird issues where it would misfire in 2nd but fine in every other gear and at the end of the night at the end of the run would have no throttle until it decided it wanted to work, so will be looking into that before a proper track night coming up in just over a week to really see the changes in the car. Messenger_creation_C9B7F84E-0820-444B-A53D-9AD40F7DDC5B.mp4     received_870009858147161.mp4   Messenger_creation_046B1D12-ABA0-4B01-B78F-262559E64ADC.mp4  by the end of the night found that if i was nice and gentle on the throttle in 2nd it wouldnt misfire so was only fully throttle and loaded up in 2nd it would occur
    • I think I will try out Frenchy’s power steering kit. Looks like a better solution.
    • Useless lot aren't they? Releasing stuff on the market that doesn't do what it's supposed to do without you stuffing about with it and spacing out the spacer lol. FFS.
    • Similar experience with Ross pulley. Can't recommend.
