Make: Nissan
Model: Skyline R32 GTS
Milage: ***
Transmission: 5spd
Colour: Charcoal
Currently registered? REG til June '08
Price: $9,500
Contact: Stephen, 0413 102 290
Comments / Modifications: Tasteful example of NA skyline. Great car, handles well with a bit of kick. Originally an R32 GST-T; engine swapped for an R33's non-turbo RB25 so transmission etc. are all built to support more power; is in great condition inside and out, regularly serviced by Steve Cramp at Manta Racing.
Just had:
New brake pads (front)
New RAA battery
New tyres (rear)
Recently had new Bosch sparkplugs, GTR engine mounts (the only ones we could find) numerous other upkeep jobs.
Lowered on aftermarket springs, aftermarket exhaust and air filter, Pioneer stereo and 6x9's, otherwise pretty much standard, very clean and neat and dearly loved, well maintained.
***I have intentionally not listed the km's (210,000 on odometer) because the engine is a lot newer and i thought putting the k's in would be unnecessarily misleading. However, the true k's on the RB25 are unknown to me.
SMS, call, PM, anytime.
Images:
Edited by stephen_
https://www.sau.com.au/forums/topic/211044-r32-gts-9500-nothing-else-to-spend/
Hey 1st 32-
Yehp spot on they are vertex sides my mate got me for my birthday, rims are just 17" with chrome lip.
Has a sunroof too; and just had new camshaft drivebelt, tensioner and idler pulley installed.
  • 4 months later...
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
