Hey all,
couldnt find any discussion on these things elsewhere.
On Ebay atm there is a guy in vic selling MARS brand turbo timers for $50 ($60 buy it now). Just wondering if anyone had used them before or if there was a better/cheaper alternative. If there crap ill pay for a better one but trying to save cash for better stuff (like a new front bar).
LINKY
thanks in advance
https://www.sau.com.au/forums/topic/211081-cheap-turbo-timer-advice/
my advice is don't buy one at all. they are a waste of time and space in your car. I have had one in most of my cars, and they all shit me. I've only bought one once when I was about 19 because I thought it would be cool, and it show'd speed, lap times etc too. since then they have all just been in cars that I bought, and if I wasn't so lazy I probably would have ripped them out. :banana:
it's far better practice to just take it easy for the last few mins of driving, let the car idle for 30 seconds or so then shut it off. :D
one of the first things i got a mate to do while helping me install a head unit was get him to turn the thing off.. cut earth wire and its all good! and no longer works!
and i absolutely hate turbo timers.
+1 on that or if you want one spend the extra $$ and get an apexi pen tiny gives you a/f and volts as well
thanks for the input (and speedy reply) :banana:
space doesnt really metter because its one of those pen size ones. Also i tend to flog my car on the way to work cos im late (Uni + work on the same day not a good idea) so i dont really have time to let it idle with me still in the car.
anyone else have a view on this?
EDIT: man you guys reply fast lol
Edited by sida102
be on time.. and let the car run for that 30 seconds while you shift thru crap in your car and gather wat you need for the day at work.. or put your shoes on with the car running.. its quite easy to do that 30 seconds or more of stuff before goin into work/uni
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
