My mechanic told me he tried to patch a leak in my down pipe. I think it's still leaking. Will this have a bad effect of the turbo? My turbo isn't going as hard and i'm throwing up
whether the exhaust is weakening boost or if the turbo is just dying.
Thoughts?
Edited by R338OY
https://www.sau.com.au/forums/topic/211102-exhaust/
Any exhaust restriction after your turbo turbine is considered bad for power... so really you should have gained some power from your leak LOL. In reality, if the leak was big enough, i guess it could cause adverse turbulence at the leak, having a follow-on effect on total flow.
https://www.sau.com.au/forums/topic/211102-exhaust/#findComment-3732650
Well i figured a leak wouldn't cause a big drop in boost, but several people have told me (including a tuner) exhaust leaks worsen performance.
Not really something to fuss about? I thought of replacing the exhaust but if it's just a rooted turbo then maybe i need to go turbo shopping.
Boost is pretty crap unless i boot it. Especially from lower rpm's it's like an NA. If i change at 2500/3000rpm i sometimes can't even hear blow-off :/
https://www.sau.com.au/forums/topic/211102-exhaust/#findComment-3733447
it may not be the exaust thats leaking, if the power has dropped off id be looking more toward the turbo gasket's, like the ones before the turbo
My exhaust manifold was repaired a few months ago, turbo came off and several gaskets were replaced.
Power wise it's not bad. 189rwkw @ 10psi is what i expected with my mods. But response down low is bad (sounds like an NA city driving) and higher up can't really hear air being compressed.
I would have thought they meant a zhaust leak before the turbo, not after it :D
Well i told everyone it was turbo-back leaking, so that's what they were referring to.
So should i look at doing the exhaust or do i need to get on Nengun and check out their Turbo platter?
Edited by R338OY
https://www.sau.com.au/forums/topic/211102-exhaust/#findComment-3734704
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
    • Nice, is there a post with the new 4" dyno curve?
