Suspension For R31
Hey everyone. Im looking at lowering my R31 S3 GXE skyline. Theres just a few questions id like to ask :P
>What is a good height for regular street use?
>Can i just get springs or do i need stuff like shocks????
>What brands of springs etc are good and what arnt?
>Will driving the car feel better/worse?
>and how much as an estimate will it cost me?
To anyone who answers any of these questions,
thanks :D
1. I'm not too sure what the best height a R31 should be for street and performance.
2. When you lower a car, it's always best to get matching shocks. You'll have to do your research as to which shocks suit each spring best.
3. I'm not too sure if brand really matter. I see 8kg/mm springs as 8kg/mm springs. :P
4. How the car feels afterwards would depend on what you did with your suspension. Lower it too much and you'll get quite a lot of bump steering and probably bottoming out depending on spring rates.
5. I can't give you a rough figure of how much it'll cost for your car, but for my car, a 1983 corolla, it set me back ~$500? or something like that. It included basic KYB shocks front and rear with lowered springs to match (from a little research I found out what spring rate springs were best suited to those shocks).
Hope that helped a little. From my post, I obviously don't know much about suspension as others on here so please forgive me. :D
Edited by adam-__-
haha thanks for sharing what you know. Yea im just gonna keep lookin for info.. Going to go into my local suspension places and inquire a bit about prices and stuff either tormorrow or after the long weekend.
thanks mate :/
How do you mean? Can you get them compressed or something?
Easy.
Seriously, I would go for a custom aurora spring (6kg/4kg for street use) and an upgraded KYB/Koni shock, a pair of swaybars and a panhard rod. Also go through and replace all the rubber bushes (which are over 20 years old now), and either add S13 lower control arms or a pair of camber tops. Can also lathe down the castor arm a little and have more thread cut on so you can pull more castor out of it. Reckon you could have it all in for $1000 - $1500..... probably less depending on what you can come up with 2nd hand/what struts you use etc.....
If you want to spend more, Id go for a S13 coilover setup, as you not only get height adjustment etc, you can add better brakes into the equation./...
I used the following...
S13 Silk Road Section RMA-8 10kg/8kg coilovers
S13 Hub/Knuckle/Stub axle with new bearings
R31 LCA with new balljoints
R31 rack/tie rods/tie rod ends (rack rebuilt, but will be switching to R32 rack at some point)
R32 GTS-T pot callipers rebuilt
R33 GTS non turbo 4 stud rotors machined, but will be switching to redrilled GTS-T turbo rotors ASAP
R31 brake lines
S13 caliper banjo bolts.
Cusco tower bar
Drift shop roll centre adjusters
Whiteline sway bar and super pro link bushes
3rds Productions Rose Jointed Adj. Castor Arms
Super pro bushing all the way through the car
and it all bolted straight together. No modding needed whatsoever.
Was a bit pricey (over $3K worth), but going to be well worth it in the end.
At the end of the day, Just depends on what you want from the car and how much you're willing to spend.
 Share
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
    • Id like to race in the US i think alot of those track would suit me   For the s15? Youd be stuck between club sprint and the new Open Am wouldnt you depending on how much interior you have left in
