Hey everyone. Im looking at lowering my R31 S3 GXE skyline. Theres just a few questions id like to ask :P
>What is a good height for regular street use?
>Can i just get springs or do i need stuff like shocks????
>What brands of springs etc are good and what arnt?
>Will driving the car feel better/worse?
>and how much as an estimate will it cost me?
To anyone who answers any of these questions,
thanks :D
https://www.sau.com.au/forums/topic/211134-suspension-for-r31/
1. I'm not too sure what the best height a R31 should be for street and performance.
2. When you lower a car, it's always best to get matching shocks. You'll have to do your research as to which shocks suit each spring best.
3. I'm not too sure if brand really matter. I see 8kg/mm springs as 8kg/mm springs. :P
4. How the car feels afterwards would depend on what you did with your suspension. Lower it too much and you'll get quite a lot of bump steering and probably bottoming out depending on spring rates.
5. I can't give you a rough figure of how much it'll cost for your car, but for my car, a 1983 corolla, it set me back ~$500? or something like that. It included basic KYB shocks front and rear with lowered springs to match (from a little research I found out what spring rate springs were best suited to those shocks).
Hope that helped a little. From my post, I obviously don't know much about suspension as others on here so please forgive me. :D
Edited by adam-__-
How do you mean? Can you get them compressed or something?
Easy.
Seriously, I would go for a custom aurora spring (6kg/4kg for street use) and an upgraded KYB/Koni shock, a pair of swaybars and a panhard rod. Also go through and replace all the rubber bushes (which are over 20 years old now), and either add S13 lower control arms or a pair of camber tops. Can also lathe down the castor arm a little and have more thread cut on so you can pull more castor out of it. Reckon you could have it all in for $1000 - $1500..... probably less depending on what you can come up with 2nd hand/what struts you use etc.....
If you want to spend more, Id go for a S13 coilover setup, as you not only get height adjustment etc, you can add better brakes into the equation./...
I used the following...
S13 Silk Road Section RMA-8 10kg/8kg coilovers
S13 Hub/Knuckle/Stub axle with new bearings
R31 LCA with new balljoints
R31 rack/tie rods/tie rod ends (rack rebuilt, but will be switching to R32 rack at some point)
R32 GTS-T pot callipers rebuilt
R33 GTS non turbo 4 stud rotors machined, but will be switching to redrilled GTS-T turbo rotors ASAP
R31 brake lines
S13 caliper banjo bolts.
Cusco tower bar
Drift shop roll centre adjusters
Whiteline sway bar and super pro link bushes
3rds Productions Rose Jointed Adj. Castor Arms
Super pro bushing all the way through the car
and it all bolted straight together. No modding needed whatsoever.
Was a bit pricey (over $3K worth), but going to be well worth it in the end.
At the end of the day, Just depends on what you want from the car and how much you're willing to spend.
    • Yeah, the latter. No diff should have a centre replaced without checking clearances because its unlikely to be the same as whatever came out. Not that that stops most people just checking a new centre in
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
