  • Replies 54
As I said to you when you were sending me "Blow by Blow" updates.... that's baller as f**k mate.
I hope to break 250 with mine, let alone 291 LOL....
We need to hook that boy up some sus and brakes on that thing now :D:)
Edited by R31 drift pig
Very impressed with the numbers however at the last minute we suspect the exhaust cam is a tooth out as with the stock cams the power came on alot earlier....Will keep you posted with more information
cubes, only specs on the cams i know is 264 duration and .64 something. thats all i can remember offhand..cost a bucket!
here are some pics!
Be interesting to see the results. Im betting the std cams will get it on power sooner, and probably make the same power anyway. Rb20s have pretty big cams std
ok dave here is just the sound track no picture 420kb
>>Michael 297kw Soundtrack<<
EDIT
for those that may want it on there Nokie Phone or MP4 compatible device i have it in a 320x240 format weights in @ 12.7mb oh and i took the soundtrack out
Yea steve, id love a copy for the nokia.
We're very pleaseed with it so far, haven't finished yet. Still some fine tuning to go. a fair bit more work smoothing out afr's and also ignition timing...but very pleased with 16psi tho...have plans for a little more boost with a little less timing just to experiment.
And
might i add, its a real animal on the road. >_<
Ryan
GREAT WORK !! Sleeper and a half !
Did you do any head work at all? Definetly still a 20 right?
yep hehe still a 20 dude, head work was really only a clean up. Valve seats and valve stem seals...but nothing performance wise.
mmmmmmmmmmm, i have the exact same turbo on an rb30 twin cam and i only make 254rwkw's @ 14psi!
hehe yea as i said, the 20 only made 250oddrwkw on 20psi before the cams...quite impressed with the way the cams turned out. Alot of money tho but the cams also eliminated a few dips higher in the power curve. We suspect was due to airflow. They disappeared straight away.
more to come in the way of earlier power delivery..
thanks for your comments guys, this was merely just a test car for us to learn how to tune. Big reps to the Microtech and the pc interface.
Ryan
Edited by Ryanrb25
Wasn't 250rwkw odd made with ~12psi once you done the cams and port matched the turbine housing + on a 35+degree day?
Once you push 15-16psi in to yours it should be up around 280rwkw.
Then the usual 18-19psi and 300rwkw which is the norm for an rb25det, rb30det with std exhaust manifold.
Swap out the std exhaust manifold and you could make 350-360rwkw without too many drama's.
But yeah.. it doesn't really sound all that angry in the vid + 16psi for 300rwkw with an xr6t turbo on an rb20 with cams does to my self sound a bee's dick high especially with a std exhaust manifold; but I try not to care. :D
It would be interesting to see how much more is in it on that dyno as the std exhaust manifold on boostworx dyno really struggles once you push 290rwkw. Increasing boost nets small power increases and tops out around 300-310rwkw absolute max. Regardless if it has cams, big turbo's or what not.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
